  • B&C 8MDN51-16 8" Professional Neodymium Woofer 16 Ohm
B&C SpeakersPart # 294-5913
Model: 8MDN51-16
Highly recommended for compact 2-way speaker systems, the B&C Speakers 8MDN51-16 8" driver also performs well as the midbass/midrange element in high-output 3-way and 4-way designs, including line arrays.
  • Great for line arrays and horn loading
  • Neodymium ring magnet assembly
  • Ventilated voice coil gap for reduced power compression
  • 2" aluminum voice coil on polyimide former
  • 400 watts continuous program power capacity
  • 70 – 4,000 Hz response
Your Price: $221.34
MSRP: $368.90
Save $147.56 (40%)
We'll send you an email when B&C 8MDN51-16 8" Professional Neodymium Woofer 16 Ohm is back in stock or available for preorder.
Ships in 7-10 Business Days
B&C's 8MDN51-16 8" woofer is an efficient and lightweight cast frame neodymium professional driver. Its ventilated voice coil gap ensures long term power handling and reduced power compression. Although the 8MDN51-16 will provide great results when loaded into direct radiating designs, it is also ideally suited for horn-loaded speaker systems.
BrandB&C Speakers
Model8MDN51-16
Part Number294-5913
UPC848864009469
Weight6.65
Nominal Diameter8"
Bolt Circle Diameter8.3
Power Handling (RMS)400 Watts
Impedance16Ω
Frequency Response70 to 4,000Hz
Sensitivity97dB 2.83V/1m
Voice Coil Diameter2"
Resonant Frequency (Fs)68Hz
DC Resistance (Re)10Ω
Voice Coil Inductance (Le)1.25mH
Mechanical Q (Qms)5.2
Electromagnetic Q (Qes)0.29
Total Q (Qts)0.27
Compliance Equivalent Volume (Vas)0.62ft³
BL Product (BL)17.8T·m
Diaphragm Mass Inc. Airload (Mms)22g
Surface Area of Cone (Sd)220cm²
Cone MaterialCoated Paper
Surround MaterialCloth
Magnet MaterialNeodymium
Overall Outside Diameter8.8"
Baffle Cutout Diameter7.4"
Depth3.74"
Sealed Volume0.2ft³
Sealed F3211.7Hz
Vented Volume0.55ft³
Vented F377.1Hz
