  • B&C 6PEV13 6-1/2" Midrange Speaker
B&C SpeakersPart # 294-650
Model: 6PEV13
The B&C Speakers 6PEV13 high efficiency 6.5" cone midrange is ideally suited for three and four way systems.
  • High efficiency allows use with powerful woofers and HF components
  • Aluminum phase plug maintains high axial sensitivity
  • Aluminum voice coil on fiberglass former
  • Smooth, detailed response
  • Die cast frame for durability and proper alignment
  • Lightweight yet well-damped paper cone with flat foam edge
B&C 6MD38 6-1/2" Midrange Speaker
Price: $127.86Part # 294-651
Your Price: $132.72
MSRP: $221.20
Save $88.48 (40%)
Only 1 In Stock More due on 3/31/2026
We'll send you an email when B&C 6PEV13 6-1/2" Midrange Speaker is back in stock or available for preorder.
B&C's 6PEV13 6-1/2" midrange speaker features great sensitivity and very smooth response from 400 Hz to 8 kHz. An aluminum phase plug increases the 6PEV13's axial sensitivity and controls its high frequency dispersion. Aluminum voice coil on fiberglass former.
BrandB&C Speakers
Model6PEV13
Part Number294-650
UPC844632002014
Weight5.3
Nominal Diameter6-1/2"
Bolt Circle Diameter6.7
Power Handling (RMS)240 Watts
Frequency Response150 to 8,000Hz
Sensitivity99dB 2.83V/1m
Voice Coil Diameter1.5"
Resonant Frequency (Fs)126Hz
DC Resistance (Re)5.2Ω
Voice Coil Inductance (Le)0.6mH
Mechanical Q (Qms)4.6
Electromagnetic Q (Qes)0.39
Total Q (Qts)0.36
Compliance Equivalent Volume (Vas)0.21ft³
BL Product (BL)8.2T·m
Diaphragm Mass Inc. Airload (Mms)6g
Surface Area of Cone (Sd)132cm²
Cone MaterialPaper
Surround MaterialFoam
Voice Coil FormerFiberglass
Magnet MaterialNeodymium
Overall Outside Diameter7.4"
Baffle Cutout Diameter5.7"
Depth3.1"
Sealed Volume0.15ft³
Sealed F3292.3Hz
Vented Volume0.22ft³
Vented F3123.7Hz
