  • B&C 18SW115-4 18" Professional Neodymium Subwoofer 4 Ohm
B&C SpeakersPart # 294-6006
Model: 18SW115-4
B&C's 18SW115-4 18" pro subwoofer speaker boasts an oversized 4.5" voice coil, neodymium motor, 1,700 watts RMS power handling capacity, and 14 mm Xmax (60 mm peak-to-peak excursion before damage).
  • Lightweight but powerful FEA-optimized neodymium magnet
  • Extremely high BL factor and Xmax for outstanding LF output
  • 14 mm Xmax, 60 mm peak-to-peak excursion before damage
  • 4.5" split winding copper voice coil on fiberglass former
  • Ventilated voice coil gap reduces power compression
  • Aluminum demodulation ring on pole piece reduces distortion
  • Double silicone spider
Your Price: $739.56
Save $493.04 (40%)
Only 3 In Stock More due on 12/4/2026
We'll send you an email when B&C 18SW115-4 18" Professional Neodymium Subwoofer 4 Ohm is back in stock or available for preorder.
The B&C 18SW115-4 is an advanced, lightweight subwoofer driver featuring 1,700 watts RMS power handling, a 1.33" long/4.5" diameter copper voice coil with very high thermal capability, and a ventilated neodymium magnet assembly that provides low power compression. An aluminum demodulation ring fitted to the 18SW115-4's pole piece reduces distortion.
BrandB&C Speakers
Model18SW115-4
Part Number294-6006
UPC848864009827
Weight30.5
Nominal Diameter18"
Bolt Circle Diameter17.44
Power Handling (RMS)3400 Watts
Impedance4Ω
Frequency Response35 to 1,500Hz
Sensitivity97dB 2.83V/1m
Voice Coil Diameter4.5"
Resonant Frequency (Fs)32Hz
DC Resistance (Re)5Ω
Voice Coil Inductance (Le)1.9mH
Mechanical Q (Qms)5.6
Electromagnetic Q (Qes)0.32
Total Q (Qts)0.3
Compliance Equivalent Volume (Vas)6.5ft³
BL Product (BL)30.3T·m
Diaphragm Mass Inc. Airload (Mms)275g
Maximum Linear Excursion (Xmax)14mm
Surface Area of Cone (Sd)1210cm²
Cone MaterialCoated Paper
Surround MaterialCloth
Voice Coil FormerFiberglass
Magnet MaterialNeodymium
Overall Outside Diameter18"
Baffle Cutout Diameter16.6"
Depth9.5"
Sealed Volume2.25ft³
Sealed F387.9Hz
Vented Volume6ft³
Vented F336.3Hz
