  • B&C 18NBX100 18" Professional Neodymium Subwoofer 8 Ohm
B&C SpeakersPart # 294-6000
Model: 18NBX100
B&C's 18NBX100 18" pro subwoofer speaker boasts an oversized 4.0" voice coil, neodymium motor, 1,200 watts RMS power handling capacity, and 10.0 mm Xmax (57 mm peak-to-peak excursion before damage).
  • Lightweight but powerful FEA-optimized neodymium magnet
  • Extremely high BL factor and Xmax for outstanding LF output
  • 10.0 mm Xmax, 57 mm peak-to-peak excursion before damage
  • 4.0" split winding copper voice coil on fiberglass former
  • Ventilated voice coil gap reduces power compression
  • Aluminum demodulation ring on pole piece reduces distortion
  • Double silicone spider
Dayton Audio Pro 18 in. 8 Ohm Subwoofer Odeum 18F
Price: $224.98Part # 295-641
Your Price: $448.56
MSRP: $747.60
Save $299.04 (40%)
Out of Stock
We'll send you an email when B&C 18NBX100 18" Professional Neodymium Subwoofer 8 Ohm is back in stock or available for preorder.
Special Order Item Ships in 3-7 Days
The B&C 18NBX100 is an advanced, lightweight subwoofer driver featuring 1,200 watts RMS power handling, a 1.00" long/4.0" diameter copper voice coil with very high thermal capability, and a ventilated neodymium magnet assembly that provides low power compression. An aluminum demodulation ring fitted to the 18NBX100's pole piece reduces distortion.
BrandB&C Speakers
Model18NBX100
Part Number294-6000
UPC848864009766
Weight23.7
Nominal Diameter18"
Bolt Circle Diameter17.3
Power Handling (RMS)2400 Watts
Frequency Response35 to 1,000Hz
Sensitivity96dB 2.83V/1m
Voice Coil Diameter4"
Resonant Frequency (Fs)35Hz
DC Resistance (Re)5.2Ω
Voice Coil Inductance (Le)1.85mH
Mechanical Q (Qms)5.6
Electromagnetic Q (Qes)0.4
Total Q (Qts)0.38
Compliance Equivalent Volume (Vas)7ft³
BL Product (BL)24.8T·m
Diaphragm Mass Inc. Airload (Mms)217g
Maximum Linear Excursion (Xmax)10mm
Surface Area of Cone (Sd)1210cm²
Cone MaterialCoated Paper
Surround MaterialCloth
Voice Coil FormerFiberglass
Magnet MaterialNeodymium
Overall Outside Diameter18"
Baffle Cutout Diameter16.6"
Depth8.3"
Sealed Volume3.5ft³
Sealed F374.4Hz
Vented Volume6ft³
Vented F337.8Hz
