  • B&C 15HCX76 15" Neodymium Coaxial Speaker 60 x 40 Degree
B&C SpeakersPart # 294-579
Model: 15HCX76
The B&C 15HCX76 marries the impressive low frequency output of a 15" woofer with the HF directivity of a coaxially mounted high-directivity large format compression driver.
  • Tight, long throw HF directivity
  • Efficient, low-distortion coaxial design
  • Strong, lightweight neodymium integrated magnetic structure
  • Woofer rated at 800 watt continuous program power handling
  • Cloth multi-roll surround, light moving mass, and exponential cone geometry
  • Titanium diaphragm high frequency driver with polyester surround
  • Circular HF waveguide
We'll send you an email when B&C 15HCX76 15" Neodymium Coaxial Speaker 60 x 40 Degree is back in stock or available for preorder.
The B&C 15HCX76 15" coaxial speaker features a tighter high frequency coverage characteristic that focuses output and improves throw. It is also useful for stage monitor applications that demand concentrated output and minimum "spillage". The 15HCX76's exceptionally precise pattern control is attributable to a carefully engineered waveguide coupled to the large-format high frequency driver.
A single, integrated neodymium magnetic assembly provides motor force to both the low and high frequency driver sections. The 15HCX76 is especially recommended for compact bass reflex enclosures and long-throw ceiling applications like hotel ballroom installations. Crossover not included. Recommended 12 dB/octave crossover frequency: 1,200 Hz.
B&C cone loudspeaker models range from 6.5" to 21", each built on a sturdy die-cast aluminum or stamped steel chassis for maximum mechanical reliability. Voice coils are wound in two layers inside-outside around polyimide or fiberglass formers, giving them the ability to withstand very high thermal stress. Loudspeaker cones are treated with a special stiffening finish, resulting in excellent rigidity and avoiding break-up problems when driven to full power.
Many B&C speakers include carefully balanced copper or aluminum rings that minimize variations in the magnetic field during operation, reducing distortion and increasing accuracy in reproduced sound. Most models also feature a specially designed cooling path through the magnet assembly to further increase power handling and lower power compression. The NDL, NW, HPL, and NCX models use powerful neodymium magnets that offer a weight reduction of up to 60%, and special chassis designs for improved cooling.
The design and optimization are performed with up-to-date Finite Element Analysis (FEA) to obtain the best combination of efficiency, linearity, and thermal exchange. Ongoing research and refining of the theoretical models and a constant updating of the measurement methods and instruments allow B&C to further increase excursion capabilities, consistency, and overall sound quality.
BrandB&C Speakers
Model15HCX76
Part Number294-579
UPC844632086182
Weight12.3
Nominal Diameter15"
Bolt Circle Diameter14.7
Power Handling (RMS)800 Watts
Impedance8Ω
Frequency Response40 to 18,000Hz
Sensitivity99dB 2.83V/1m
Voice Coil Diameter3"
Resonant Frequency (Fs)38Hz
DC Resistance (Re)5.1Ω
Voice Coil Inductance (Le)0.9mH
Mechanical Q (Qms)5.8
Electromagnetic Q (Qes)0.3
Total Q (Qts)0.28
Compliance Equivalent Volume (Vas)8.6ft³
BL Product (BL)17.8T·m
Diaphragm Mass Inc. Airload (Mms)82g
Maximum Linear Excursion (Xmax)4.5mm
Surface Area of Cone (Sd)855cm²
Cone MaterialPaper
Magnet MaterialNeodymium
Overall Outside Diameter15.5"
Baffle Cutout Diameter13.94"
Depth7.8"
Sealed Volume1.25ft³
Sealed F3107.7Hz
Vented Volume3ft³
Vented F350.8Hz
