  • B&C 15CXN88 15" Neodymium Coaxial Speaker 80 x 80 Degree
B&C SpeakersPart # 294-6038
Model: 15CXN88
The powerful motor and large voice coils give the B&C Speakers 15CXN88 15" coaxial full range speaker more output capability and lower distortion than most high output coaxial speakers on the market. When space is a concern, this driver is perfect for providing high fidelity and maximum output capability.
  • Coaxial HF driver with 3" voice coil, titanium diaphragm, and 80° nominal coverage
  • Neodymium ring magnet shared by LF and HF components keeps weight low
  • 3.5" woofer voice coil ensures good power handling
  • Use with passive or active crossover (not included)
Your Price: $820.74
Save $547.16 (40%)
Out of Stock
We'll send you an email when B&C 15CXN88 15" Neodymium Coaxial Speaker 80 x 80 Degree is back in stock or available for preorder.
Special Order Item Ships in 3-7 Days
B&C Speakers' 15CXN88 15" coaxial driver combines a powerful woofer and high output horn tweeter into a convenient compact package. By using a massive neodymium motor, B&C allowed enough space to use a huge 3-1/2" voice coil on the woofer to make it possible to fit a powerful compression driver with a 3" titanium diaphragm. This construction gives the 15CXN88 the ability to deliver high output full-range response with incredibly low distortion.
The low frequency driver portion of the 15CXN88 has the power handling and excursion capability to produces powerful bass with the natural midrange response you expect from B&C drivers. The huge 3-1/2" voice coil is wound on a glass fiber former to handle 500 watts RMS (1,000 watts peak). The high power handling combined with 100 dB sensitivity (2.83V/1m) gives the woofer amazing output capability. Also, with over 19 mm of peak-to-peak excursion capability, the 15CXN88 can move a lot of air for powerful bass response and impact. Finally, the naturally damped paper cone produces smooth response and even has a waterproof coating for use in less than ideal situations.
The 15CXN88's high frequency assembly has been engineered to be an ideal match for the woofer. The 3" titanium dome produces extremely wide frequency response, making for an easy transition to the woofer. At 106 dB efficient (2.83V/1m) the high frequency unit only needs a small amount of attenuation to properly match up with the low frequency driver for flat response. It's controlled 80° conical dispersion pattern is perfect for filling a large area with sound while minimizing unwanted reflections. All of this makes the 15CXN88 one of the most capable coaxial drivers on the market.
Specifications (Woofer): • Power Handling: 500 watts RMS/ 1,000 watts continuous program • VC dia: 3.5" • Le: 1.05 mH • Impedance: 8 ohms • Re: 5.0 ohms • Frequency response: 40 – 3,000 Hz • Fs: 40 Hz • SPL: 100 dB 2.83V/1m • Vas: 6.29 cu. ft. • Qms: 10.3 • Qes: 0.26 • Qts: 0.25 • Xmax: 8.5 mm • Xvar: 9.5 mm.
Specifications (Compression driver): • Diaphragm: Titanium • Power handling: 80 watts RMS/ 160 watts continuous program (with recommended crossover of 1,200 Hz/12 dB slope) • VCdia: 3" • Impedance: 8 ohms • Frequency response: 1,200 – 18,000 Hz • SPL: 106 dB 2.83V/1m
Dimensions: • Outside diameter: 15.47" • Cutout diameter: 14.02" • Depth: 8.19"
BrandB&C Speakers
Model15CXN88
Part Number294-6038
UPC848864050645
Weight20.55
Nominal Diameter15"
Bolt Circle Diameter14.72
Frequency Response40 to 18,000Hz
Sensitivity100dB 2.83V/1m
Voice Coil Diameter3.5"
Resonant Frequency (Fs)40Hz
DC Resistance (Re)
Voice Coil Inductance (Le)1.05mH
Mechanical Q (Qms)10.3
Electromagnetic Q (Qes)0.26
Total Q (Qts)0.25
Compliance Equivalent Volume (Vas)6.29ft³
Mechanical Compliance of Suspension (Cms)0.17mm/N
BL Product (BL)21.2T·m
Diaphragm Mass Inc. Airload (Mms)93g
Maximum Linear Excursion (Xmax)8.5mm
Surface Area of Cone (Sd)855cm²
Cone MaterialTreated Paper
Surround MaterialCloth
Voice Coil FormerFiberglass
Magnet MaterialNeodymium
Overall Outside Diameter15.47"
Baffle Cutout Diameter14.02"
Depth8.19"
Sealed Volume0.85ft³
Sealed F3126.7Hz
Vented Volume3ft³
Vented F347.4Hz
