  • B&C 12CXN88 12" Professional Coaxial Speaker 80 x 80 Degree 8 Ohm
B&C SpeakersPart # 294-5791
Model: 12CXN88
The powerful motor and large voice coils give the B&C Speakers 12CXN88 12" coaxial full range speaker more output capability and lower distortion than most high output coaxial speakers on the market. When space is a concern, this driver is perfect for providing high fidelity and maximum output capability.
  • Massive motor assembly allows room for a 3.5" LF voice coil and 3" HF voice coil
  • Large voice coils for high power handling to produce maximum output with low distortion
  • Woofer has high excursion capability to produce powerful low frequency response
  • 3" high frequency driver can handle low crossover point for smooth transition to the woofer
Your Price: $782.52
Save $521.68 (40%)
We'll send you an email when B&C 12CXN88 12" Professional Coaxial Speaker 80 x 80 Degree 8 Ohm is back in stock or available for preorder.
B&C Speakers' 12CXN88 12" coaxial driver combines a powerful woofer and high output horn tweeter into a convenient compact package. By using a massive neodymium motor, B&C allowed enough space to use a huge 3-1/2" voice coil on the woofer to make it possible to fit a powerful compression driver with a 3" titanium diaphragm. This construction gives the 12CXN88 the ability to deliver high output full-range response with incredibly low distortion.
The low frequency driver portion of the 12CXN88 has the power handling and excursion capability to produces powerful bass with the natural midrange response you expect from B&C drivers. The huge 3-1/2" voice coil is wound on a glass fiber former to handle 500 watts RMS (1,000 watts peak). The high power handling combined with 100 dB sensitivity (2.83V/1m) gives the woofer amazing output capability. Also, with over 20 mm of peak-to-peak excursion, the 12CXN88 can move a lot of air for powerful bass response and impact. Finally, the naturally damped paper cone produces smooth response and even has a waterproof coating for use in less than ideal situations.
The 12CXN88's high frequency assembly has been engineered to be an ideal match for the woofer. The 3" titanium dome produces extremely wide frequency response, making for an easy transition to the woofer. At 106 dB efficient (2.83V/1m) the high frequency unit only needs a small amount of attenuation to properly match up with the low frequency driver for flat response. It's controlled 80° conical dispersion pattern is perfect for filling a large area with sound while minimizing unwanted reflections. All of this makes the 12CXN88 one of the most capable coaxial drivers on the market.
Specifications (Woofer): • Power Handling: 500 watts RMS/ 1,000 watts continuous program • VC dia: 3.5" • Le: 1.05 mH • Impedance: 8 ohms • Re: 5.0 ohms • Frequency response: 50 – 3,000 Hz • Fs: 50 Hz • SPL: 100 dB 2.83V/1m • Vas: 2.08 cu. ft. • Qms: 8.3 • Qes: 0.23 • Qts: 0.22 • Xmax: 8 mm • Xvar: 10.5 mm.
Specifications (Compression driver): • Diaphragm: Titanium • Power handling: 80 watts RMS/ 160 watts continuous program (with recommended crossover of 1,200 Hz/12 dB slope) • VCdia: 3" • Impedance: 8 ohms • Frequency response: 1,200 – 18,000 Hz • SPL: 106 dB 2.83V/1m
Dimensions: • Outside diameter: 12.4" • Cutout diameter: 11.18" • Depth: 7.01"
BrandB&C Speakers
Model12CXN88
Part Number294-5791
UPC848864062785
Weight18.2
Nominal Diameter12"
Bolt Circle Diameter11.7
Frequency Response50 to 18,000Hz
Sensitivity100dB 2.83V/1m
Voice Coil Diameter3.5"
Resonant Frequency (Fs)50Hz
DC Resistance (Re)
Voice Coil Inductance (Le)1.05mH
Mechanical Q (Qms)8.3
Electromagnetic Q (Qes)0.23
Total Q (Qts)0.22
Compliance Equivalent Volume (Vas)2.08ft³
Mechanical Compliance of Suspension (Cms)6.34mm/N
BL Product (BL)20.9T·m
Diaphragm Mass Inc. Airload (Mms)60g
Maximum Linear Excursion (Xmax)8mm
Surface Area of Cone (Sd)522cm²
Cone MaterialTreated Paper
Surround MaterialCloth
Voice Coil FormerFiberglass
Magnet MaterialNeodymium
Overall Outside Diameter12.4"
Baffle Cutout Diameter11.18"
Depth7.01"
Sealed Volume0.5ft³
Sealed F3196.3Hz
Vented Volume1.13ft³
Vented F358.5Hz
