  • B&C 10MBX64 10" Professional Neodymium Woofer 8 Ohm
B&C SpeakersPart # 294-6016
Model: 10MBX64
The 10MBX64 from B&C Speakers provides surprisingly wide frequency response and extremely high output making it perfect for use in compact 2-way sound reinforcement systems.
  • Neodymium magnet produces more output with less weight
  • Aluminum shorting ring keeps distortion low
  • MBX Series drivers are ideal for use in compact 2-way loudspeaker designs
  • Weatherproof cone for use in less than ideal outdoor conditions
Your Price: $259.56
Save $173.04 (40%)
Only 4 In Stock
We'll send you an email when B&C 10MBX64 10" Professional Neodymium Woofer 8 Ohm is back in stock or available for preorder.
Order in the next 3 hr 13 min to ship today. Details
The 10MBX64 10" mid-bass woofer from B&C Speakers offers acoustic designers a high efficiency, wide bandwidth driver capable of surprising output levels. This full-featured transducer incorporates a lightweight neodymium motor, inside/outside wound copper clad aluminum wire voice coil, weatherproof hydrophobic paper cone, and a symmetrical inductance profile. Everything about this driver has been designed for reliable and consistent low distortion output even when driven to its limit. All MBX Series drivers are especially well suited for 2-way loudspeaker designs.
BrandB&C Speakers
Model10MBX64
Part Number294-6016
UPC848864032597
Weight8.55
Nominal Diameter10"
Bolt Circle Diameter9.65
Power Handling (RMS)700 Watts
Impedance8Ω
Frequency Response65 to 6,000Hz
Sensitivity99dB 2.83V/1m
Voice Coil Diameter2.5"
Resonant Frequency (Fs)65Hz
DC Resistance (Re)5.4Ω
Voice Coil Inductance (Le)0.44mH
Mechanical Q (Qms)4
Electromagnetic Q (Qes)0.28
Total Q (Qts)0.26
Compliance Equivalent Volume (Vas)0.92ft³
BL Product (BL)17.1T·m
Diaphragm Mass Inc. Airload (Mms)33g
Surface Area of Cone (Sd)53.63cm²
Cone MaterialTreated Paper
Surround MaterialCloth
Voice Coil FormerFiberglass
Magnet MaterialNeodymium
Overall Outside Diameter10.28"
Baffle Cutout Diameter9.06"
Depth4.92"
Sealed Volume0.4ft³
Sealed F3219.6Hz
Vented Volume0.75ft³
Vented F375.9Hz
