  • Aurasound NS2x3-184-4A 2" x 3" Extended Range Driver 4 Ohm
CLEARANCE Aurasound NS2x3-184-4A 2" x 3" Extended Range Driver 4 Ohm
AuraSoundPart # 296-256
Model: NS2x3-184-4A
Aurasound designed the 2" x 3" full-range NS2x3 driver with bleeding edge loudspeaker technology for the highest quality, full-range sound, in the smallest possible package. Great for modern applications such as speaker bars, desktop computer speakers, thin tower speakers, and line arrays.
  • NRT radial neodymium motor for extremely low distortion
  • Underhung motor for great frequency response linearity
  • Small frame size for reduced center-to-center distance and reduced comb filtering when used in arrays
  • Great for modern audio applications including sound bars and ultra-thin tower speakers
We'll send you an email when Aurasound NS2x3-184-4A 2" x 3" Extended Range Driver 4 Ohm is back in stock or available for preorder.
The Aurasound NS2x3-184-4A 2" x 3" full-range driver is packed with next-gen speaker technology. An NRT™ neodymium radial magnet motor submerses the 18.4 mm, underhung voice coil in magnetic flux for supreme control, low distortion, high output (for its size), and wide frequency range without stray magnetic fields that could potentially damage sensitive electronics, while the extreme venting provided by a capless pole piece evacuates air that would otherwise be compressed (in a driver this size).
A paper cone is mated to a rubber impregnated cloth surround to reduce cone breakup, for an extremely linear frequency response from 200 to 20,000 Hz. The low, 220 Hz free air resonance allows for low crossover points, meaning you can pair the NS2x3-164-4A with nearly any woofer up to 5 feet away (2-1/2 ft. is the recommended maximum) seamlessly.
BrandAuraSound
ModelNS2x3-184-4A
Part Number296-256
UPC848864016245
Weight0.34
Nominal Diameter2 x 3"
Power Handling (RMS)7 Watts
Power Handling (MAX)15 Watts
Frequency Response200 to 20,000Hz
Sensitivity84dB 2.83V/1m
Voice Coil Diameter0.72"
Resonant Frequency (Fs)220Hz
DC Resistance (Re)3.5Ω
Mechanical Q (Qms)4.9
Electromagnetic Q (Qes)1.9
Total Q (Qts)1.38
Compliance Equivalent Volume (Vas)0.01ft³
Mechanical Compliance of Suspension (Cms)0.41mm/N
BL Product (BL)1.8T·m
Diaphragm Mass Inc. Airload (Mms)1.26g
Maximum Linear Excursion (Xmax)0.43mm
Surface Area of Cone (Sd)25.72cm²
Cone MaterialPaper
Surround MaterialCloth
Voice Coil Wire MaterialCCA
Magnet MaterialNeodymium
Overall Outside Diameter1.97" x 3.54"
Baffle Cutout Diameter1.73" x 3.31"
Depth1.55"
Sealed Volume0.00744ft³
Sealed F3230.6Hz
Vented Volume0.11ft³
Vented F3142.5Hz
