  • Audtek SSW-6 Speaker Selector Switch Impedance Matching 1 In 6 Out
CLEARANCE Audtek SSW-6 Speaker Selector Switch Impedance Matching 1 In 6 Out
Audtek ElectronicsPart # 300-973
Model: SSW-6
The Audtek SSW-6 low-profile speaker selector box allows you to distribute a stereo amplifier to six separate zones. Front plate zone selection buttons make it easy to turn zones on and off. Built-in selectable protection circuit ensures total impedance does not drop below unsafe operating levels.
  • Distribute a stereo speaker level signal across up to six listening areas
  • Easily turn zones on and off from ergonomic front panel zone selection buttons
  • Selectable protection circuit to ensure total impedance does not drop below 5 ohms
  • High-quality push-pin terminals accept up to 14 AWG for long cable runs
CLEARANCE $21.36
MSRP: $42.99
Save $21.63 (50%)
36 In Stock
We'll send you an email when Audtek SSW-6 Speaker Selector Switch Impedance Matching 1 In 6 Out is back in stock or available for preorder.
The Audtek SSW-6 low-profile speaker selector box allows you to distribute a stereo amplifier to six separate zones. Accepting stereo speaker-level (amplified) signal, the SSW-6 provides up to 140 WPC for your zones. Front plate zone selection buttons make it easy to turn zones on and off.
Including a manually activated impedance protection circuit that can be turned ON, the SSW-6 prevents the impedance to your amplifier from dropping below an unsafe level of 5 ohms. The protection circuit ensures proper performance regardless of the number and impedance ratings of your speakers. The protector switch can also be turned off when used as part of a planned system of impedance matching volume controls, allowing you to get most out of your amplifier.
Output zones: 6 x Stereo
Protection circuit resistors: 2 x 10 ohm/15 WPC
Power handling (protection on): 70 WPC
Power handling (protection off): 140 WPC
Input connections: 1 x high-level with push-pin terminals (up to 14 AWG)
Output connections: 4 x push-pin terminals (up to 14 AWG)
Dimensions: 17" x 4.4" x 1.9"
BrandAudtek Electronics
ModelSSW-6
Part Number300-973
UPC848864063126
Weight4.2
