  • Audtek Platinum 8 AWG Power Terminal Pair
CLEARANCE Audtek Platinum 8 AWG Power Terminal Pair
Audtek ElectronicsPart # 263-686
Model: PPT8
Serious power requires a serious connector, and the Audtek ring terminals get the job done with style. 5/16" ring size.
CLEARANCE $2.59
MSRP: $13.99
Save $11.40 (81%)
34 In Stock
We'll send you an email when Audtek Platinum 8 AWG Power Terminal Pair is back in stock or available for preorder.
Serious power requires a serious connector, and the Audtek ring terminals get the job done with style. Solid construction with a beautiful simulated platinum finish at a price that will get you hooked up. Compression style wire mount. 5/16" ring size, great for use with the Audtek tri-oval battery terminals. Sold in pairs, color stripe indicates polarity. Dimensions: Overall length: 2", Overall diameter: 0.50", Max wire diameter: 0.20", Max insulation diameter: 0.28".
BrandAudtek Electronics
ModelPPT8
Part Number263-686
UPC844632016752
Weight0.12
Connector TypeRing
Terminal / Stud Size5/16"
Wire Gauge8 AWG
