  • Audio-Technica PRO 45 Hanging Condenser Microphone
Audio-TechnicaPart # 242-412
Model: PRO 45
The PRO45 is a versatile, ultra-miniature, permanently installed microphone designed for high quality recording, broadcast and sound reinforcement applications.
  • Flat, smooth frequency response
  • Operates on 9-52V DC phantom power
  • Rugged design and construction for reliable service
  • One year manufacturer warranty
Your Price: $109.00
We'll send you an email when Audio-Technica PRO 45 Hanging Condenser Microphone is back in stock or available for preorder.
The PRO45 is a versatile, ultra-miniature, permanently installed microphone designed for high quality recording, broadcast and sound reinforcement applications. The high SPL handling capability makes it perfect for suspension over choir, orchestra or stage. Wide-range condenser elements with low-mass diaphragms provide superior performance, and a uniform cardioid polar pattern for maximum rejection of unwanted sounds. Self-contained electronics eliminate the need for external power modules.
Specifications: • Polar Pattern: Cardioid (unidirectional) • Frequency response: 70-16,000 Hz • Maximum SPL: 134 dB • Signal to Noise ratio: 66 dB • Dynamic range: 106 dB • Weight (less cable): 0.5 oz. • Dimensions: 0.47" (head dia.) x 2.24" (L) • Includes 25 ft. permanently attached cable w/3-pin XLR male type connector, foam windscreen and steel hanger.
BrandAudio-Technica
ModelPRO 45
Part Number242-412
Weight0.25
Element TypeCondenser
On/Off SwitchNo
Polar PatternCardioid
