  • Audio-Technica ATW-902a System 9 Handheld Wireless Microphone System
Audio-TechnicaPart # 242-5229
Model: ATW-902a
The Audio-Technica ATW-902a System 9 four-channel frequency wireless system features the ATW-R900a receiver and the ATW-T902a dynamic, unidirectional, handheld microphone with a transmitter. The system has four selectable VHF channels (169.505, 170.245, 171.045, and 171.905 MHz).
  • Four selectable VHF channels (169 to 172 MHz)
  • Balanced XLR and unbalanced 1/4" output jacks ensure compatibility with a wide range of audio products
  • Easy set-up and clear, natural sound quality for stress free gigs
  • Reliable performance and durable construction
  • Advanced dipole antenna system that allows for an extended operating range
Your Price: $209.00
We'll send you an email when Audio-Technica ATW-902a System 9 Handheld Wireless Microphone System is back in stock or available for preorder.
Audio-Technica's System 9 handheld wireless microphone system provides your rig with great flexibility. The sleek, stylish, stackable design of the receiver also features balanced XLR and unbalanced 1/4" outputs so that the system can be used with a variety of audio products. Easy-setup and operation of the unit allows you to spend less time hassling with the product and more time rocking your gig.
In addition to ease of use, the ATW-902a provides you with a clear, natural sound quality and with reliable performance and durability. The receiver's advanced dipole antenna system means that the system has an extended range of operation so you don't have to stress about the microphone dropping signal. The system has a four-channel user-selectable frequency channels from 169 to 172 MHz.
Specifications for the system: • Operating frequencies: VHF high band (169.505, 170.245, 171.045, and 171.905 MHz ) • Modulation mode: FM • Dynamic range: >=90 dB (A-weighted), typical • Total harmonic distortion: <1% (at 1,000 Hz) • Operating range: 200 ft. (60 m) • Frequency response: 80 to 13,000 Hz.
Specifications for the ATW-R900a receiver: • Receiving system: Non-diversity, single-channel, dual antenna system • XLR audio output: balanced, 350 mV • 1/4" audio output: unbalanced, 700 mV • Power supply: 100~240 VAC to 12 VDC • Dimensions 7.48" W x 1.82" H x 5.06" D.
Specifications for the transmitter: • RF power output: 10 mW • Batteries: Two 1.5V AA (not included) • Dimensions: 9.91" long, 2.11" diameter.
BrandAudio-Technica
ModelATW-902a
Part Number242-5229
UPC4961310141202
Weight2.9
Frequency BandVHF
