  • Audio-Technica ATW-1301/L System 10 PRO Digital Wireless Lavalier System
CLEARANCE Audio-Technica ATW-1301/L System 10 PRO Digital Wireless Lavalier System
Audio-TechnicaPart # 242-5316
Model: ATW-1301/L
The Audio-Technica ATW-1301/L System utilizes a rugged half-rack chassis is designed to accommodate two receiver units, which can be operated locally or detached from the chassis and positioned remotely at distances of up to 328 feet via Ethernet cable. For expanded capabilities, you can link up to five chassis, totaling 10 receiver units, using the RJ12 cables provided with each system. This configuration creates a robust, multichannel system that can simultaneously handle up to 10 channels.
  • Digital 24-bit/48 kHz wireless operation for ultimate sound quality and dependable performance
  • Operates in the 2.4 GHz range – completely free from TV interference
  • Up to five chassis (ten receiver units) can be linked and used simultaneously
  • Each receiver unit can be paired with up to 10 transmitters, allowing users to instantly switch between different transmitter configurations
  • Ground-lift switch helps eliminate audible hum caused by ground loops
CLEARANCE $599.00
1 In Stock
We'll send you an email when Audio-Technica ATW-1301/L System 10 PRO Digital Wireless Lavalier System is back in stock or available for preorder.
Order in the next 6 hr 1 min to ship today. Details
Much like all the other members of the System 10 wireless family, the PRO Rack-Mount offers 24-bit performance, effortless setup, crystal-clear and authentic sound quality, and three layers of diversity assurance: frequency, time, and space. Frequency Diversity transmits the signal over two dynamically allocated frequencies to ensure interference-free communication. Time Diversity sends the signal in multiple time slots, maximizing resistance to multipath interference. Space Diversity employs two antennas on both the transmitter and receiver units, optimizing signal integrity.
Each System 10 PRO Rack-Mount system includes an ATW-RC13 receiver chassis with rack-mount adapters, one or two ATW-RU13 receiver units accompanied by corresponding AT8690 receiver unit mounting brackets, a joining plate (exclusive to dual-channel systems), an RJ12 cable, an AC adapter, and one or two transmitters. Transmitter options encompass the ATW-T1001 cW-style body-pack transmitter, ATW-T1002 handheld transmitter, ATW-T1006 boundary microphone/transmitter, and ATW-T1007 microphone desk stand transmitter. Both the receiver chassis and transmitters feature user-friendly displays for convenient operation.
Overall System Specifications:
• Operating frequency: 2.4 GHz ISM band (2400 to 2483.5 MHz)
• Maximum deviation: ±40 kHz
• Dynamic range: > 110 dB (A-weighted), typical
• THD: < 0.05% typical
• Operating range: 60 m (200') typical; open range environment with no interfering signals
• Operating temperature range: 32º F to 104º F (0º C to 40º C)
• Frequency response: 20 Hz to 20 kHz (+1 dB, -3 dB)
Receiver Specifications
• Receiving system: True diversity
• Power requirements: 12V DC, 500 mA
• Dimensions: 8.27" W x 6.67" D x 1.73" H not including BNC connectors or feet
• Accessories included: AC adapter, Link cable, Rack-mount adapters, Joining plate, Rubber feet
Body-Pack Transmitter Specifications:
• RF power output: 10 mW
• Spurious emissions: Following federal and national regulations
• Input connections: Four-pin locking connectors; Pin 1: GND, Pin 2: INST, INPUT, Pin 3: MIC INPUT, Pin 4: DC BIAS +9V
• Batteries Two 1.5V AA, not included
• Battery life: High 7 hours (alkaline) depending on battery type and use pattern
• Dimensions: 2.76" W x 0.98" D x 4.21" H
BrandAudio-Technica
ModelATW-1301/L
Part Number242-5316
UPC4961310130817
Weight5.5
Frequency BandDigital
