  • Audio-Technica ATN3600LC Replacement Stylus
Audio-TechnicaPart # 240-5563
Model: ATN3600LC
The ATN3600 stylus is the replacement stylus for the AT3600L cartridge. This 6 mil conical stylus is made to be compatible with several Audio-Technica turntables, including the AT-LP60X series, AT-LP60 series, AT-LP2D series, AT-PL300 series, AT-SB727, AT-SB2022, AT-LPGO-BT, and AT-PL50. It can also work with turntables of other brands; please consult your turntable's user manual to learn if the AT3600LC is right for you.
  • Replacement stylus for the Audio-Technica AT3600L cartridge
  • The successor to the ATN3600L, updated with a new modern design
  • Compatible with several Audio-Technica Turntables
  • Potentially compatible with other brand turntables. Consult your user manual
  • The conical bonded stylus and diamond tip offer the sound quality that Audio-Technica has been perfecting since 1962
Your Price: $36.00
We'll send you an email when Audio-Technica ATN3600LC Replacement Stylus is back in stock or available for preorder.
This updated version of the iconic ATN3600L conical bonded stylus, trusted by millions of music enthusiasts for decades, features a fresh, modern design while maintaining the same ease of use, reliability, and sound quality that made it the go-to replacement stylus for countless turntables.
Compatible with these Audio-Technica turntables: AT-LP60X series, AT-LP60 series, AT-LP2D series, AT-PL300 series, AT-SB727, AT-SB2022, AT-LPGO-BT, AT-PL50. The ATN3600LC is compatible with turntables from other brands, as well. To confirm compatibility, consult your turntable’s user manual or contact the manufacturer.
Cartridge & Stylus
  • Vertical Tracking Force 3.0 to 4.0 g (3.5 g standard)
  • Stylus Shape Conical bonded
  • Dimensions 0.6 mil
  • Stylus Life Approx. 300–500 hours
Replacement Process
1. To remove old stylus (needle), hold the cartridge in one hand, grasp the plastic stylus housing with thumb and forefinger, and pull away from the cartridge. The stylus assembly comes away at a slight angle, as indicated by the arrow.
 2. To install replacement stylus, insert the new stylus assembly into the cartridge at a slight angle, so the hook at the end of the stylus fits into the slot in the cartridge body. The stylus assembly should click into place when fully seated on the cartridge. The stylus must be fully seated on the body for proper operation.
BrandAudio-Technica
ModelATN3600LC
Part Number240-5563
UPC4961310162542
Replacement ForAudio-Technica
