  • Audio-Technica AT-XP5/H Dual Moving Magnet Stereo Audiophile DJ Cartridge with AT-HS6BK Headshell
Audio-TechnicaPart # 240-5541
Model: AT-XP5/H
The Audio-Technica AT-XP5/H Dual Moving Magnet Stereo Audiophile DJ Cartridge with Headshell Combo Kit is specially designed for DJs but works great for causal listening. The AT-XP5/H includes the AT-XP5 DJ cartridge pre-mounted on the AT-HS6BK headshell. A 0.3 x 0.7 mil elliptical bonded stylus tracks the center of the record groove for reliable performance and excellent fidelity. The cartridge design provides maximum visibility of the stylus tip to easily location the location of playback.
  • Audiophile cartridge equipped with a 0.3 x 0.7 mil elliptical stylus and VM dual magnet construction for a 5.5mV high-level output level suited for professional DJ applications
  • Carbon fiber-reinforced ABS cantilever ensure precise tracking
  • Durable robust design for high-quality specialist DJ playback
  • Compatible with the replacement styli ATN-XP7 for an upgrade
  • Tracking force of 2.0 to 4.0 grams (3.0 grams standard)
  • Audiophile DJ cartridge AT-XP5 pre-mounted on the AT-HS6BK Headshell
Your Price: $119.00
Out of Stock
We'll send you an email when Audio-Technica AT-XP5/H Dual Moving Magnet Stereo Audiophile DJ Cartridge with AT-HS6BK Headshell is back in stock or available for preorder.
The AT-XP5 cartridge features a highly-rigid polyphenylene sulfide (PPS)/glass fiber body, has a tracking force of 2 to 4 grams, and offers a powerful output level of 5.5 mV. Its 0.3 x 0.7 mil elliptical bonded stylus tracks the center of the record groove for reliable performance and excellent fidelity. The cartridge design provides maximum visibility of the stylus tip. The AT-XP5 cartridge is pre-mounted onto the 9g aluminum die cast body AT-HS6BK headshell.
The AT-XP series cartridges provide a high quality sound for vinyl DJ’s. Offering all of the features of a DJ cartridge, but with a Hi-fi sound, the XP series are perfect for the stage and club DJ who prioritizes sound quality.
The durable carbon fiber-reinforced ABS cantilever and nylon wire suspension ensure precise tracking. Providing great tracking and channel separation the AT-XP5 produces a high-fidelity sound which is essential for both DJ and casual listening applications.
The AT-XP5 cartridge is compatible with any XP or VM95 Series replacement stylus, offering a wide choice of options for every budget and application. Compatible with the replacement styli ATN-XP5 and ATN-XP7 for an upgrade of audio fidelity.
• Mounting: 1/2"
• Frequency response: 20 - 18,000 Hz
• Channel separation: 20 dB (1 kHz)
• Output channel balance: 2.0 dB (1 kHz)
• Output voltage: 5.5mV (@ 1 kHz, 5cm/sec)
• Vertical tracking angle: 20 degrees
• Vertical tracking force range: 2 - 4g (standard 3 )
• Stylus shape: Elliptical
• Stylus size: 0.3 x 0.7mil
• Stylus construction: Bonded round shank
• Cantilever: Carbon reinforced ABS
• Coil impedance: 6.7 kohms (1 kHz)
• Coil inductance: 1H (1 kHz)
• Recommended load impedance: 47 kohms
• Recommended load capacitance: 100-200 pF
• Replacement stylus: ATN-XP5
• Weight: 15.6g (cartridge & headshell)
• Dimensions: 21.2mm H x 21.4mm W x 62.4mm D (cartridge & headshell)
BrandAudio-Technica
ModelAT-XP5/H
Part Number240-5541
UPC4961310146566
Weight0.17
