  • Audio-Technica AT-SP3X Powered Bookshelf Speakers
CLEARANCE Audio-Technica AT-SP3X Powered Bookshelf Speakers
Audio-TechnicaPart # 240-5740
Model: AT-SP3X
The Audio-Technica AT-SP3X Powered Bookshelf Speakers are versatile and compact, offering wired or wireless connectivity via Bluetooth and dual RCA jacks. They may be small, but these speakers deliver a powerful, well-balanced sound, perfect for use with turntables, computers, and other devices. The built-in DSP ensures optimized audio performance, while the powered design allows for easy setup without the need for an external receiver.
  • Equipped with dual RCA jacks for wired connection and Bluetooth technology for wireless connection
  • Specially tuned to deliver impressive, full-range audio
  • Ideal audio solution for turntables, PCs, smartphones, and other devices
  • Multipoint pairing function allows you to stay connected to two Bluetooth devices at once
  • Minimalistic design suits any room
  • Power button with LED indicator and volume control dial provide easy operation
  • Simplified powered speaker setup does not require an external receiver/amplifier
See all items in Bluetooth & Wireless Speakers
CLEARANCE $219.00
Save $50.00 (19%)
2 In Stock
We'll send you an email when Audio-Technica AT-SP3X Powered Bookshelf Speakers is back in stock or available for preorder.
Order in the next 4 hr 32 min to ship today. Details
The Audio-Technica AT-SP3X Powered Bookshelf Speakers combine sleek design and powerful performance, making them an ideal solution for various audio setups. Whether connected via Bluetooth for wireless convenience or through the dual RCA jacks for a wired experience, these speakers deliver rich, dynamic sound with their 3" woofers and 1.1" tweeters. This versatility allows them to pair perfectly with turntables, computers, smartphones, and other audio devices, providing flexibility for any environment.
Featuring built-in Digital Signal Processing (DSP), the AT-SP3X speakers are fine-tuned for optimal audio performance, enhancing clarity and depth across different types of media. The DSP ensures that whether you’re listening to music, watching movies, or gaming, the sound quality remains consistently crisp and immersive. The speakers are powered by an AC adapter, eliminating the need for an external receiver or amplifier, which simplifies setup while delivering robust sound.
Combine the best of both the modern and vintage together by combining the AT-SP3X with the Audio-Technica AT-LP70X Fully Automatic Belt-Drive Turntable. Designed to fit seamlessly together, the combination of this turntable and these powered speakers will leave even the most discerning listener impressed. With the AT-SP3X, Audio-Technica offers an ideal combination of convenience, style, and superior sound performance for a wide range of audio needs.
  • Speaker Unit: 76 mm (3.0") dia. x 2
  • Tweeter Unit: 27 mm (1.1") dia. x 2
  • Maximum Output: 30W
  • Frequency Response: 55 to 20,000 Hz
  • Communication System: Compliant with Bluetooth standard Ver. 5.3
  • Maximum RF Output: 10 mW EIRP
  • Maximum Communication Range: Line of sight - approx. 10 m (33')
  • Frequency Band: 2.4 GHz band (2.402 GHz to 2.480 GHz)
  • Modulation Method: GFSK, Pi/4DQPSK, 8DPSK
  • Spread Spectrum Method: FHSS
  • Compatible Bluetooth Profiles: A2DP
  • Support Codec: SBC
  • Supported Content Protection Method: SCMS-T
  • Supported Sample Rates: 44.1 kHz, 48 kHz
  • Supported Bit Rates: 16 bit, 24 bit
  • Transmission Band: 20 to 20,000 Hz
  • Power Supply: AC100-240V / DC18V (using supplied AC adapter)
  • Input Jack: Analog audio input terminals (RCA pin plug x 2)
  • Speaker Cord Length: 2.0 m (6.6')
  • AC Adapter Cord Length: 1.2 m (3.9')
  • Dimensions: 200 mm (7.9") x 113 mm (4.9") x 145 mm (5.4") (H x W x D)(excluding protrusions)
  • Weight:
    -Left Side: Approx. 1.5 kg (3.3 lbs)
    -Right Side: Approx. 1.6 kg (3.5 lbs)
  • Operating Temperature: 5°C to 40°C (41°F to 104°F)
  • Accessories Included: AC adapter, AC adapter replacement plug x 4, speaker cable (for L/R connection), rubber foot x 8
  • Notes: For product improvement, the product is subject to modification without notice.
BrandAudio-Technica
ModelAT-SP3X
Part Number240-5740
UPC4961310162184
Weight8.95
ColorBlack
Configuration2-way
Mounting StyleSet-Top
Woofer Diameter3"
Special FeaturesBluetooth
