  • Audio-Technica AT-LP3BK Fully Automatic Belt-Drive Stereo Turntable - Black
CLEARANCE Audio-Technica AT-LP3BK Fully Automatic Belt-Drive Stereo Turntable - Black
Audio-TechnicaPart # 240-5702
Model: AT-LP3XBK
Dust off your record collection and prepare for the undeniably enjoyable experience of playing records on your Audio-Technica AT-LP3BK. This turntable features a fully automatic belt-driven platter that can be switched between 33-1/3 and 45 RPM.
  • Fully adjustable counterweight and anti-skate mechanisms
  • Built-in switchable phono pre-amplifier with RCA output cables
  • Fully automatic belt-drive turntable operation with two speeds: 33-1/3 and
  • Includes 45 RPM adapter and removable hinged dust cover
  • Balanced straight tone arm with hydraulically damped lift control and rest
  • 1/2" mount universal headshell with AT91R Dual Moving Magnet phono cartridge and long-life diamond stylus
CLEARANCE $379.00
1 In Stock
We'll send you an email when Audio-Technica AT-LP3BK Fully Automatic Belt-Drive Stereo Turntable - Black is back in stock or available for preorder.
The AT-LP3 fully automatic belt-drive turntable lets you take your analog listening experience to the next level with advanced features not typically found on automatic turntables. The balanced straight tone arm comes with a 1/2" mount universal headshell and AT91R dual moving magnet phono cartridge, giving you excellent high-fidelity performance, plus the option to use other moving magnet or moving coil cartridges of your choosing.
A hydraulically damped lift control allows the stylus to be precisely and safely lowered and raised at any point on a record. Yet the turntable also offers fully automatic operation, so you can simply press the start button to begin play and the stop button to lift and return the tone arm and shut off the turntable (the stop function occurs automatically when a record has played all the way through).
The AT-LP3 is constructed of anti-vibration damping materials that limits low-frequency feedback. Resonance is further reduced by the turntable’s die-cast aluminum platter and accompanying 4 mm rubber damping mat. Equipped to play both 33-1/3 and 45 RPM records, the AT-LP3 features a built-in switchable phono preamp and an attached dual RCA output cable that enable it be connected to a home stereo, powered speakers and other components whether they have a dedicated turntable input or not.
Specifications: • Type: Belt-drive turntable, fully automatic • Motor: DC servo-controlled • Speeds: 33-1/3 RPM, 45 RPM • Turntable platter: Die-cast aluminum • Wow and flutter: Less than 0.25% (WTD) @ 3 kHz (JIS) • Signal-to-noise ratio: >50 dB (DIN-B) • Output level: Pre-amp: 1.5-3.6 mV nominal at 1 kHz, 5 cm/sec • Pre-amp: 129-313 mV nominal at 1 kHz, 5 cm/sec • Phono pre-amp gain: 36 dB nominal, RIAA equalized • Accessories included: AT91R Dual Moving Magnet stereo cartridge with replaceable stylus; 1/2" mount universal headshell; power cord; 45 RPM adapter; removable hinged dust cover; 4 mm rubber mat • Power supply requirements: 120V AC, 60 Hz • Dimensions: 17.1" W x 5.0" H x 13.8" D.
BrandAudio-Technica
ModelAT-LP3XBK
Part Number240-5702
Weight17.45
Drive TypeBelt Drive
