  • Audio-Technica AT-HS3 Universal 1/2" Mount Headshell for 4-Pin Turntable Catridge Red
CLEARANCE Audio-Technica AT-HS3 Universal 1/2" Mount Headshell for 4-Pin Turntable Catridge Red
Audio-TechnicaPart # 240-5728
Model: AT-HS3
Designed for use with the AT-LP3 turntable, this universal ½"-mount headshell is an excellent fit for any turntable with a straight 4-pin tonearm.
  • Universal ½"-mount headshell for 4-pin tonearms
  • Lightweight aluminum die-cast body keeps vibration to a minimum
  • Angled shape suitable for straight tonearms
  • Finger lift enables precise stylus placement
  • Vivid red coloring
  • Includes lead wires and mounting screws
We'll send you an email when Audio-Technica AT-HS3 Universal 1/2" Mount Headshell for 4-Pin Turntable Catridge Red is back in stock or available for preorder.
Tailored for compatibility with the AT-LP3 turntable, the universal ½"-mount headshell is well-suited for any turntable featuring a straight 4-pin tonearm. The AT-HS3 boasts a lightweight aluminum die-cast body, effectively minimizing vibrations. Its finger lift allows for precise stylus placement, and the headshell comes with color-coded lead wires and mounting screws for added convenience.
  • Material: Aluminum
  • Connector: Aluminum
  • Weight: 11.1g (0.4 oz)
  • Dimensions: 15mm (0.6") H x 21mm (0.8" W x 48mm (1.9") D
  • Included: Installation screws x2, nuts x2, plastic washers x2
BrandAudio-Technica
ModelAT-HS3
Part Number240-5728
