  • AtlasIED WD417-72V 8" Slant Wall Mount Speaker
AtlasIEDPart # 242-9427
Model: WD417-72V
This loudspeaker/baffle package features a walnut grain wall baffle/enclosure with an attractive black fabric grille. Baffles are designed with a 9.5° slope to provide directional sound dispersion offset in the direction of radiation.
  • 9.5° Sloped Design Offers Directional Sound Projection
  • Attractive Design is Suitable for Use in a Variety of Surface- Mount Applications
  • Includes High-Quality 8" Loudspeaker with Line Transformer
  • Knob /Screwdriver-Adjust Volume Control
Your Price: $93.99
Save $19.00 (17%)
We'll send you an email when AtlasIED WD417-72V 8" Slant Wall Mount Speaker is back in stock or available for preorder.
This loudspeaker/baffle package features a walnut grain wall baffle/enclosure with an attractive black fabric grille. Baffles are designed with a 9.5° slope to provide directional sound dispersion offset in the direction of radiation. Each package contains a high-quality 8" dia. loudspeaker with 5-ounce ceramic magnet and includes a pre-assembled dual-voltage transformer. This package also includes a 50 ohm pot volume control for individual loudspeaker adjustment. Knob may be removed and volume adjusted with a screwdriver to provide additional security if required.
Specifications: • Height: 10-1/2" (26.67 cm) • Width: 9-1/2" (24.13 cm) • Depth: 5-1/2" (13.97 cm) • Shipping weight: 5.50 lbs. (2.49 kg) • Power taps: .5, 1, 2, 4.
BrandAtlasIED
ModelWD417-72V
Part Number242-9427
UPC612079128990
Weight5.5
ColorWalnut Grain
ConfigurationFull-range
Input Rating70V|25V
Mounting StyleWall Mount
Woofer Diameter8"
Special FeaturesAngled
