  • AtlasIED TSD-TXHL High / Low Level Converter
AtlasIEDPart # 242-9488
Model: TSD-TXHL
The TSD-TXHL from Atlas Sound is a high to low level signal converter for those situations where you need to expand an existing (or new) distributed audio system, and changing your amplified signal back to line level is preferable to running three miles of cable (again).
  • Converts amplified signal to line level
  • Compatible with 4 ohm, and 25/70/100V systems
  • Simple screw terminal connections
  • Independent control of input gain and output level
Your Price: $83.99
MSRP: $99.99
Save $16.00 (16%)
Out of Stock
We'll send you an email when AtlasIED TSD-TXHL High / Low Level Converter is back in stock or available for preorder.
The AtlasIED TSD-TXHL is a high to low level converter designed to interface with 4 ohm/25/70/100V distributed speaker lines. An unbalanced line level output is provided to drive remote amplifiers or other devices from your existing amplified signal path. The TSD-TXHL allows easy expansion of zones without the need for dedicated wiring to remote locations. The high to low-level converter features an isolated transformer, which will not add measurable load to the speaker line. An output level control allows for trim adjustment to best match the remote amplifier (or other device) input sensitivity. The TSD-TXHL works perfectly in conjunction with AtlasIED's CP and PA series amplifiers. And, up to four TSD series devices may be secured in a single rack space (1RU) with the TSD-RMK rack mount kit (sold separately).
BrandAtlasIED
ModelTSD-TXHL
Part Number242-9488
UPC612079187881
Weight0.65
