  • AtlasIED SHS-TB Elevated Tile Bridge for Thin Ceilings for SHS-6T2
AtlasIEDPart # 242-835
Model: SHS-TB
The Atlas Sound SHS-TB Tile Bridge is designed to work with the SHS-6T2 Strategically Hidden Speaker in applications with ceiling tile or material that is less than 0.5" thick. The SHS-TB ensures that the diffuser can properly attach the diffuser to the SHS with no gap at the ceiling tile.
  • Ensures proper spacing for sound chamber and diffuser lens in materials thinner than 0.5"
  • Constructed of 24-gauge electro-galvanized steel
We'll send you an email when AtlasIED SHS-TB Elevated Tile Bridge for Thin Ceilings for SHS-6T2 is back in stock or available for preorder.
The AtlasIED SHS-TB Tile Bridge is designed to work with the SHS-6T2 Strategically Hidden Speaker in applications with ceiling tile or material that is less than 0.5" thick. The SHS-TB ensures that the diffuser can properly attach the diffuser to the SHS with no gap at the ceiling tile.
Commercial Audio Design Made Easy
Need help with commercial audio design considerations? Try Atlas's comprehensive Speaker Placement Tool to assist with proper speaker positioning within a given space. Using this resource be confident that you are using the correct speakers for your unique environmental constraints.
Specifications: • Diameter: 6-1/2" • Dimensions: 23-3/4" H x 8" W x 0.5" D.
BrandAtlasIED
ModelSHS-TB
Part Number242-835
UPC612079664825
Weight3.4
