  • AtlasIED HT327 32 Watt High-Quality Speaker Line Matching Transformer
AtlasIEDPart # 242-9375
Model: HT327
The HT327 features high power handling with minimal insertion loss and wide frequency response to provide quality line matching of loudspeakers in high power systems.
  • Constructed with audio grade laminations
  • Frequency response is +/- 1 dB from 30 Hz to 15 kHz
  • High power handling unit
  • High quality matching transformer with only 0.6 dB insertion loss
  • Primary taps of 8, 16, & 32 watts
  • Secondary outputs offer both 4 & 8 ohm impedance
Your Price: $106.99
Save $21.00 (16%)
We'll send you an email when AtlasIED HT327 32 Watt High-Quality Speaker Line Matching Transformer is back in stock or available for preorder.
Order in the next 14 hr 38 min to ship today. Details
The HT327 features high power handling with minimal insertion loss and wide frequency response to provide quality line matching of loudspeakers in high power systems. Unit is constructed of audio grade laminations and offers primary taps at 8, 16 and 32 watts with secondary impedance of 4 and 8 ohms. Insertion loss does not exceed 0.6 dB and the unit operates within a frequency range of +1 dB from 30 Hz to 15 kHz. The transformer is designed for external mounting to surfaces other than the loudspeaker.
Specifications: • Height: 3-1/4" (8.26 cm) • Width: 2-1/2" (6.35 cm) • Depth: 3-1/4" (8.26 cm) • Shipping weight: 3.50 lbs (1.59 kg) • Frequency response: +1 dB-30 Hz-15 kHz • Power taps: 8, 16 & 32 • Power rating: 32W • Primary voltage: 70.7.
BrandAtlasIED
ModelHT327
Part Number242-9375
UPC612079114436
Weight3.05
