  • AtlasIED FAPSUB-1 8" Subwoofer System Each
CLEARANCE AtlasIED FAPSUB-1 8" Subwoofer System Each
AtlasIEDPart # 242-809
Model: FABSUB-1
The AtlasIED FAPSUB adds impressive low frequency response to any full range distributed system. Sold individually.
  • Easy installation in drop tile or sheetrock ceilings via included C-ring/V-rail tile bridge
  • Also incorporates "dog leg" mounting system
  • Front mounted tap selector switch for easy system tuning adjustments
  • Includes transformer bypass setting for 8 ohm direct coupled operation
  • Extended low frequency response from the optimally tuned and ported deep galvanized steel enclosure
  • 4-pole detachable "phoenix" style connector allows for easy pre-wiring and daisy chaining
  • Enhanced quality 70.7V/100V internal transformer minimizes insertion loss and maintains LF response
CLEARANCE $351.99
Save $85.00 (19%)
3 In Stock
We'll send you an email when AtlasIED FAPSUB-1 8" Subwoofer System Each is back in stock or available for preorder.
Order in the next 9 hr 19 min to ship today. Details
AtlasIED's Strategy Series® II premium ceiling speaker packages will satisfy the needs of owners, architects, contractors, and consultants by delivering true, high fidelity sound reproduction in an attractive and easy-to-install system. These high-performance systems are perfectly suited for many business music and public address applications. Each speaker system ships complete with speaker/transformer factory assembled into back can, grill, and unique C-ring/V-rail mounting hardware.
The FAPSUB adds impressive low frequency response to any full range distributed system. A high efficiency passive crossover network eliminates the need for a dedicated amplifier and/or active crossover, while its low crossover point greatly reduces localization. Sold individually.
Specifications: • Power rating: 100 watts/200 watts max (transformer limited) • 70.7V Taps: 1.9, 3.8, 7.5, 15, 30, 60 watts • Frequency response: 45-120 Hz (±10 dB) • Low pass filter: 120 Hz (18 dB/octave) • Dimensions: Overall: 15-3/4" dia. x 12-3/4" H; Cutout: 14" dia.
BrandAtlasIED
ModelFABSUB-1
Part Number242-809
UPC612079181100
Weight43
Input Rating8 ohm|70V|100V
Mounting StyleIn-ceiling
Woofer Diameter8"
Special FeaturesEnclosed Back-UL1480
