  • AtlasIED FAP62T 6" Speaker System Pair
CLEARANCE AtlasIED FAP62T 6" Speaker System Pair
AtlasIEDPart # 242-806
Model: FAP62T
Compact profile enclosure and wide dispersion make the FAP62T a perfect choice for low ceilings.
  • Easy installation in drop tile or sheetrock ceilings via included C-ring/V-rail tile bridge
  • Also incorporates "dog leg" mounting system
  • Front mounted tap selector switch for easy system tuning adjustments
  • Includes transformer bypass setting for 8 ohm direct coupled operation
  • Extended low frequency response from the optimally tuned and ported deep galvanized steel enclosure
  • 4-pole detachable "phoenix" style connector allows for easy pre-wiring and daisy chaining
  • Enhanced quality 70.7V/100V internal transformer minimizes insertion loss and maintains LF response
CLEARANCE $363.99
MSRP: $447.99
Save $84.00 (19%)
1 In Stock
We'll send you an email when AtlasIED FAP62T 6" Speaker System Pair is back in stock or available for preorder.
AtlasIED's Strategy Series® II premium ceiling speaker packages will satisfy the needs of owners, architects, contractors, and consultants by delivering true, high fidelity sound reproduction in an attractive and easy-to-install system. These high-performance systems are perfectly suited for many business music and public address applications. Each speaker system ships complete with speaker/transformer factory assembled into back can, grill, and unique C-ring/V-rail mounting hardware. Sold in pairs, priced per pair. Compact profile enclosure and wide dispersion make the FAP62T a perfect choice for low ceilings.
Specifications: • Power rating: 50 watts (transformer limited) • 70.7V Taps: 2, 4, 8, 16, 32 watts • Frequency response: 63 Hz-20 kHz • Dispersion: 110° • Dimensions: Overall: 12-1/2" dia. x 8-1/2" H; Cutout: 11" dia.
BrandAtlasIED
ModelFAP62T
Part Number242-806
UPC612079179831
Unit of MeasurePairs
Weight29.45
Input Rating8 ohm|70V|100V
Mounting StyleIn-ceiling
Woofer Diameter6"
Special FeaturesEnclosed Back-UL1480
