  • AtlasIED FAP42TC 4" Speaker System Pair
CLEARANCE AtlasIED FAP42TC 4" Speaker System Pair
AtlasIEDPart # 242-804
Model: FAP42TC
With an overall depth of 4" the FAP42TC is the perfect choice when high fidelity audio and wide, even coverage is required but space above the plenum is limited.
  • Easy installation in drop tile or sheetrock ceilings via included C-ring/V-rail tile bridge
  • Also incorporates "dog leg" mounting system
  • Front mounted tap selector switch for easy system tuning adjustments
  • Includes transformer bypass setting for 8 ohm direct coupled operation
  • Extended low frequency response from the optimally tuned and ported deep galvanized steel enclosure
  • 4-pole detachable "phoenix" style connector allows for easy pre-wiring and daisy chaining
  • Enhanced quality 70.7V/100V internal transformer minimizes insertion loss and maintains LF response
AtlasIED FAP42T 4" Speaker System Pair
Price: $225.00Part # 242-802
See all items in Commercial Ceiling Speakers
CLEARANCE $195.00
MSRP: $385.99
Save $190.99 (49%)
1 In Stock
We'll send you an email when AtlasIED FAP42TC 4" Speaker System Pair is back in stock or available for preorder.
Order in the next 5 hr 47 min to ship today. Details
AtlasIED's Strategy Series® II premium ceiling speaker packages will satisfy the needs of owners, architects, contractors, and consultants by delivering true, high fidelity sound reproduction in an attractive and easy-to-install system. These high-performance systems are perfectly suited for many business music and public address applications. Each speaker system ships complete with speaker/transformer factory assembled into back can, grill, and unique C-ring/V-rail mounting hardware. Sold in pairs, priced per pair. With an overall depth of 4" (102 mm) the FAP42TC is the perfect choice when high fidelity audio and wide, even coverage is required but space above the plenum is limited. For wall mount applications (tanning salons or surround sound) the short 4" depth will even work in most stud wall installations.
Specifications: • Power rating: 16 watts (transformer limited) • 70.7V Taps: 1, 2, 4, 8, 16 watts • Frequency response: 75 Hz-20 kHz • Dispersion: 130° • Dimensions: Overall: 10-1/2" dia. x 4-1/4" H; Cutout: 9" dia.
BrandAtlasIED
ModelFAP42TC
Part Number242-804
UPC612079181209
Unit of MeasurePairs
Weight10
Input Rating8 ohm|70V|100V
Mounting StyleIn-ceiling
Woofer Diameter4"
Special FeaturesEnclosed Back-UL1480
