  • AtlasIED FAP40T 4" Speaker System Pair
CLEARANCE AtlasIED FAP40T 4" Speaker System Pair
AtlasIEDPart # 242-800
Model: FAP40T
The high frequency response of the FAP40T is so natural that many would assume that the driver was a coaxial design instead of a single cone driver.
  • Tuned & ported design for extended bass response
  • 16 watt internal transformer with 8 ohm transformer bypass setting
  • Low profile, UL 1480 plastic enclosure
  • Input via 2 pole terminal strip
  • Press-fit grill blends perfectly into contemporary architecture
  • Lightweight construction makes use of additional support in drywall ceilings unnecessary
  • Easy installation via "dog leg" mounting system and included tile bridges
JBL Control 24CT Micro 4" 2-Way Ceiling Speaker Pair
Price: $211.09Part # 246-702
See all items in Commercial Ceiling Speakers
We'll send you an email when AtlasIED FAP40T 4" Speaker System Pair is back in stock or available for preorder.
AtlasIED's Strategy Series® II premium ceiling speaker packages will satisfy the needs of owners, architects, contractors, and consultants by delivering true, high fidelity sound reproduction in an attractive and easy-to-install system. These high-performance systems are perfectly suited for many business music and public address applications. Each speaker system ships complete with speaker/transformer factory assembled into back can, grill, and mounting hardware. Sold in pairs, priced per pair. The high frequency response of the FAP40T is so natural that many would assume the driver was a coaxial design instead of a single cone driver. The switch "knob" also functions as a diffuser cone, providing smooth, even dispersion of the high frequency content from the center of the 4" polypropylene driver.
Specifications: • Power rating: 16 watts • 70.7V Taps: 1, 2, 4, 8, 16 watts • Frequency response: 80 Hz-15 kHz (±5 dB) • Dimensions: Overall: 7-3/8" dia. x 7-1/8" H; Cutout: 6-5/16" dia.
BrandAtlasIED
ModelFAP40T
Part Number242-800
UPC612079180653
Unit of MeasurePairs
Weight8.5
Input Rating8 ohm|70V
Mounting StyleIn-ceiling
Woofer Diameter4"
Special FeaturesEnclosed Back-UL1480
