  • AtlasIED EZHD72W 8" Pre-Assembled Ceiling Speaker Baffle
AtlasIEDPart # 242-9360
Model: EZHD72W
The EZ Mount Support System transfers the composite weight of the loudspeaker, baffle, and enclosure to the ceiling’s support members via adjustable support rails (included).
  • 62-8 Style grill with white finish
  • Equipped with 25/70.7V transformer
  • Quick assembly in standard 2 x 4 suspended Tile ceilings
Your Price: $72.99
MSRP: $88.99
Save $16.00 (18%)
We'll send you an email when AtlasIED EZHD72W 8" Pre-Assembled Ceiling Speaker Baffle is back in stock or available for preorder.
The EZ Mount Support System transfers the composite weight of the loudspeaker, baffle, and enclosure to the ceiling's support members via adjustable support rails (included). The rails may be adjusted vertically and then secured to the specially designed, pre-mounted enclosure brackets with screws (furnished). No tile bridge or time-consuming screw mounting is necessary.
Specifications: • Depth: 2-7/8" (7.30 cm) • Diameter: 8" (20.32 cm) • Shipping weight: 5.17 lbs (2.35 kg) • Frequency response: 100 Hz - 10 kHz, ± 1.5 dB • Power taps: .25, .5, 1, 2, 5 • Speaker type: Treated paper • Dispersion: 105° • Sensitivity: 97 dB Peak, 94 dB Average.
BrandAtlasIED
ModelEZHD72W
Part Number242-9360
UPC612079113088
Weight6.5
Input Rating70V|25V
Mounting StyleIn-ceiling
Woofer Diameter8"
