  • AtlasIED CP400 Dual Channel Commercial Duty Power Amp
AtlasIEDPart # 242-9352
Model: CP400
A professional grade audio power amplifier specifically designed for demanding contractor applications, the CP400 features esoteric grade toroidal power supply and output transformers.
  • 25V, 70.7V, 100V, and direct coupled outputs mounted on barrier strips with covers for safety
  • Balanced inputs on barrier strip and XLR connectors
  • Dual-speed, high efficiency fan cooling
  • Loop through feature on male XLRs, one per channel input
  • Power-up muting
  • Short-circuit, temperature, and DC offset protection
  • Soft clip limiter protection
We'll send you an email when AtlasIED CP400 Dual Channel Commercial Duty Power Amp is back in stock or available for preorder.
A professional grade audio power amplifier specifically designed for demanding contractor applications, the CP400 features esoteric grade toroidal power supply and output transformers. These transformers were chosen for their outstanding reliability as well as extended frequency response (-3 dB @ 30 Hz - 16 kHz via transformer output) Now you can have the peace of mind that systems specified with the CP400 will have true transformer output isolation, a feature that previously may have not been affordable due to the cost of quality external transformers. CP400's two independent channels ensure maximum channel separation and ultra low distortion figures while providing years of faithful service. Whether your application is a large distributed constant voltage sound system or a high SPL sound reinforcement system, the AtlasIED CP400 is the perfect answer for high power/low cost amplification needs.
Specifications: • Height: 5.2" (13.18 cm) • Width: 18.9" (48.01 cm) • Depth: 16.9" (42.80 cm) • Channels: Two • Connector type: Terminal block & XLR • Finish: Black • Number of fans: 1 - Variable speed • Frequency response: Transformer output: 30 Hz - 16 kHz (±3 dB); 2, 4, & 8O Output: 30 Hz - 50 kHz (±3 dB) • Output power: • 25V Stereo: 175 watts x2 • 70.7V stereo: 200 watts x2 • 100V stereo: 200 watts x2 • 140V/200V bridged mono: 400 watts • 8O stereo: 160 watts x2 • 4O stereo: 240 watts x2 • 2O stereo; 270 watts x2 • 8O bridged mono: 500 watts • 4O bridged mono: 600 watts.
BrandAtlasIED
ModelCP400
Part Number242-9352
UPC612079185757
Weight48.7
Power Output (RMS @ 70V)101W to 200W
Weight Range40 to 49 lbs.
