  • AtlasIED ATPLATE-052 Attenuator Rack Mounting Plate Holds up to 6 Attenuators
AtlasIEDPart # 242-9468
Model: ATPLATE-052
The Atlas Sound ATPLATE-052, a 2RU high #14 gauge plate pre-punched to accommodate up to (6) Atlas Sound RM attenuators.
  • 2RU high #14 gauge plate pre-punched to accommodate up to (6) AtlasIED RM attenuators
  • Attractive black filler plugs are provided for applications where the ATPLATE will not be fully loaded
  • Finished in flat black epoxy to better blend in with other rack mount equipment
  • Perfect for rack mount applications where attenuators are required
Your Price: $46.99
MSRP: $54.99
Save $8.00 (15%)
We'll send you an email when AtlasIED ATPLATE-052 Attenuator Rack Mounting Plate Holds up to 6 Attenuators is back in stock or available for preorder.
AtlasIED ATPLATE is perfect for rack mount applications where attenuators are required. The AtlasIED ATPLATE, a 2RU high #14 gauge plate pre-punched to accommodate up to (6) AtlasIED RM attenuators. Attractive black filler plugs are provided for applications where the ATPLATE will not be fully loaded.
Please note that dial scales are included with AtlasIED RM series attenuators, however for convenience, (6) additional dial scales are included with the ATPLATE. This allows the contractor to stock only standard single gang plate AtlasIED attenuators which can be modified for use with the ATPLATE by simply removing the single gang stainless steel plate. The ATPLATE is finished in flat black epoxy to better blend in with other rack mount equipment. Attenuators sold separately.
Specifications: • Dimensions: 3-1/2" H x 19" W x 5/8" D • Color: Ebony black • Panel type: Steel • Rack spaces: 2.
BrandAtlasIED
ModelATPLATE-052
Part Number242-9468
UPC612079179473
Weight2
Construction MaterialSteel
Panel TypeAttenuator Mounting
Rack Spaces2
StyleFlat
