  • Arlington Industries DVFR3W 3-Gang Recessed Indoor High/Low Voltage InBox New/Retrofit Construction
CLEARANCE Arlington Industries DVFR3W 3-Gang Recessed Indoor High/Low Voltage InBox New/Retrofit Construction
Arlington IndustriesPart # 261-4240
Model: DVFR3W
The Arlington DVFR3W triple gang InBox allows you to run high and low voltage cables behind the wall so your TV and furniture can be mounted or placed flush against the wall.
  • Paintable white edges to fit in with your decor
  • Mounting wings hold the box securely against drywall
  • Low voltage divider included for multiple gang boxes
  • Adjusts to fit 1/4" to 1-1/2" wall thicknesses
CLEARANCE $25.03
Save $13.96 (36%)
3 In Stock
We'll send you an email when Arlington Industries DVFR3W 3-Gang Recessed Indoor High/Low Voltage InBox New/Retrofit Construction is back in stock or available for preorder.
Arlington Industries DVFR3W recessed InBox allows your flat screen TVs, furniture and countertop items to be mounted or placed flush against the wall. Made of sturdy, non-metallic material, the boxes are recessed so your plugs and connectors stay inside without extending past the wall. Designed for new construction and retrofit projects, mounting wing brackets hold the box securely against the drywall. The supplied separator allows power or low voltage cables to be installed in the same box. UL and CSA listed. Made in the USA.
BrandArlington Industries
ModelDVFR3W
Part Number261-4240
UPC018997143402
Weight1.4
FinishWhite
SizeTriple Gang
