  • Amplifier Kit 2 x 150W with Volume Treble Bass and line Input/ Output Jacks
CLEARANCE Amplifier Kit 2 x 150W with Volume Treble Bass and line Input/ Output Jacks
AC InfinityPart # 320-6150
It's time to crank up your next audio project with the KAB-2150, 2 x 150W peak, amplifier Kit. The KAB-2150 amplifier kit comes with the enclosure, power supply, wiring harnesses and all the connectors you need build a 300W amplifier. With built-in Bluetooth 5.0, and input and output line options, this amp DIY kit fills many needs that premade amps leave out.
  • External volume, Bass, and treble controls let you customize sound right out of the box
  • Plug-N-Play JST-PH and Molex Mini-Fit type wire harnesses make installation quick and simple
  • Bluetooth 5.0 for wireless connectivity
  • Efficient 2 x 150 watts of power from the TPA-3255 amp chip
  • Line input and line output wiring harnesses with 3.5 mm jacks let you instantly add other components to your project
  • External Bluetooth antenna for maximum range
Build it Your Way
The KAB-2150 amplifier kit presents an exciting opportunity for audio enthusiasts and DIY aficionados alike. With a peak output of 2 x 150W, this kit not only packs a punch but also offers customization and comprehensive set of features that enhance its overall value. You may not like the way the volume and tone controls are arranged, so customize them simply by changing the wiring harnesses around. You also have the option to change the knobs (sold separately).
Includes all the Parts You Need
One of the standout aspects of the KAB-2150 is its complete package. It comes with everything you need to assemble your own powerful 300W amplifier, including the enclosure, power supply, connectors, and wiring harnesses that plug directly into the amp board. This all-in-one approach simplifies the building process, making it approachable even for those who may have limited experience in electronics
Bluetooth Wireless Connectivity
Furthermore, the inclusion of Bluetooth 5.0 is a significant advantage. This modern wireless capability allows users to connect their devices seamlessly, eliminating the clutter of cables and providing greater flexibility in how you use your amplifier. The availability of multiple input and output line options ensures that this kit can adapt to a variety of audio setups, filling in the gaps that many off-the-shelf amplifiers might not address.
Building Takes Commitment and a Little Soldering
However, it is important to recognize that assembling any DIY kit requires a commitment to the process. This means dedicating time to understand the components and their functions, as well as the assembly instructions. You do have to solder eight wires to eight terminals, but there's no soldering any electronic components. While this may present a challenge to some, it’s also part of the excitement and satisfaction that comes from building something with your own hands.
Learn While You Build
Engaging with the KAB-2150 will not only enhance your listening experience but also provide valuable skills in electronics and assembly. As you take on this project, remind yourself that every step brings you closer to not just a functional amplifier, but also to a deeper understanding of audio technology. Embrace the journey, and enjoy the rewarding outcome of your efforts—the KAB-2150 is a compelling catalyst for your next audio adventure!
Part Number320-6150
UPC848864080093
Weight3.62
Power (RMS/Channel 8 ohms)51 - 100 Watts
Weight Range< 10 lbs.
Special FeaturesBluetooth
