  • Amphenol KS3P 3.5mm Stereo Mini Plug Connector Satin
CLEARANCE Amphenol KS3P 3.5mm Stereo Mini Plug Connector Satin
Amphenol AudioPart # 092-0150
Model: KS3P
The KS3P 3.5 mm mini connector is a good example of Amphenol's commitment to a high performance to cost ratio -- perfect for the next time you need to make a cable for headphones, MP3 player, or car aux port.
  • Accepts cables with OD from 2.5 – 5 mm (.1" - .2")
  • Robust diecast shell with satin nickel finish
  • Flexible grommet cable protection
  • Precision machined contacts are durable and easy to solder
We'll send you an email when Amphenol KS3P 3.5mm Stereo Mini Plug Connector Satin is back in stock or available for preorder.
Don't toss out your headphones because of a bad 3.5 mm plug. With the KS3P and a quick soldering session, they'll live again! They're also an ideal solution for making your own 3.5 mm male to male cables, headphone cables, and auxiliary cables for the horde of modern devices with 3.5 mm jacks.
Amphenol Australia has manufactured and designed innovative audio connectors since 1955. The company's K Series 3.5 mm phone plugs show how the company is committed to high-value connectors that perform look as good as they perform.
Specifications: • Shell: diecast • Finish: satin • Dimensions: 0.406" x 1.911".
BrandAmphenol Audio
ModelKS3P
Part Number092-0150
UPC884957035304
Weight0.005
ConductorsStereo TRS
GenderMale / Plug
Jacket ColorSilver
Mounting TypeCable Mount
