  • Mini Amp Aluminum Enclosure 3-5/8" D x 5-1/2" W x 1-9/16" H with Mounting Flanges - 2 Tone
CLEARANCE Mini Amp Aluminum Enclosure 3-5/8" D x 5-1/2" W x 1-9/16" H with Mounting Flanges - 2 Tone
Parts ExpressPart # 320-425
Surround your next audio project with this two-tone professionally finished aluminum enclosure with mounting flanges. Its small size is perfect for making an amplifier or preamplifier.
  • Mounting flanges to anchor it down to cabinets
  • Two-tone nostalgic look
  • Removable front and rear panels for easy access
  • Durable all aluminum metal project box
  • 93 x 139 x 40mm with flanges
  • Perfect size for small amplifier boards
CLEARANCE $3.50
MSRP: $9.99
Save $6.49 (65%)
1191 In Stock
We'll send you an email when Mini Amp Aluminum Enclosure 3-5/8" D x 5-1/2" W x 1-9/16" H with Mounting Flanges - 2 Tone is back in stock or available for preorder.
Order in the next 4 hr 20 min to ship today. Details
Create multiple types of amplifiers with this two-tone metal enclosure. Make your own subwoofer amplifier that mounts on the rear of the cabinet. Make your own vehicle amplifier that is small enough to mount under a seat. The outer dimensions including the flanges are only 3-5/8" D x 5-1/2" W x 1-9/16" H. Design a preamplifier for an existing amplifier to add Bluetooth, DSP, or analog tone controls. The inside dimensions are 3-1/2" x 4-3/16" x 1-3/8" will accommodate most preamp and small amplifier boards. Allow 1/8" for the internal corner screw holes. The DIY audio projects are endless. Make sure to add an external antenna to any wireless projects.
The two-tone nostalgic look and the sturdy lightweight aluminum give your DIY project a professional finish. The outer box has a black durable aluminum shell while the silver front/rear aluminum panels are ready for hole drilling if needed. The black metal flanges make it possible to secure your project under a seat, on/in a cabinet, or on a wall.
Part Number320-425
UPC848864066479
Weight0.5
Construction MaterialAluminum
