  • Aluminum Black Project Box 6.1" x 4.17"x 1.34" with Plastic Front & Back Plates
CLEARANCE Aluminum Black Project Box 6.1" x 4.17"x 1.34" with Plastic Front & Back Plates
Parts ExpressPart # 320-421
Build your next DIY project in this protective, professional looking black metal enclosure. It splits apart for easy board installation and the plastic end caps make drilling holes a breeze.
  • Durable black aluminum case splits apart for easy access
  • Plastic end caps make it easy to install connectors and electrical components
We'll send you an email when Aluminum Black Project Box 6.1" x 4.17"x 1.34" with Plastic Front & Back Plates is back in stock or available for preorder.
Use this black metal project box for your next audio DIY project. The top pops off to enable you to easily install your board/boards and run wires to all your connectors and electronic components. The plastic end caps make it easy to drill holes and mount the connectors and components. The inside diameter is 155 x 99 x 30 mm which is room for many small amplifier boards. The side panels are 36 H x 108 W x 6 D mm. The package includes eight black screws for a professional looking finish.
Part Number320-421
UPC848864066394
Weight0.6
Construction MaterialAluminum
