  • Alphasonik AW8250G 8 Gauge Ground Wire Roll 250 ft Black
CLEARANCE Alphasonik AW8250G 8 Gauge Ground Wire Roll 250 ft Black
AlphasonikPart # 268-720
Model: AW8250G
Elevate your car audio system's performance with the Alphasonik AW8250G 8 Gauge Ground Wire Roll. This extensive 250-foot roll of black ground wire is meticulously engineered to provide superior conductivity and durability, ensuring your sound system operates flawlessly. Ideal for car audio enthusiasts and professional installers alike, this wire delivers the reliable grounding essential for high-quality audio.
  • Length: 250 feet for extensive reach
  • Gauge: 8 gauge for excellent conductivity
  • Color: Black for a sleek, unobtrusive look
  • Material: High-quality construction for durability
  • Usage: Perfect for car audio and other high-power applications
We'll send you an email when Alphasonik AW8250G 8 Gauge Ground Wire Roll 250 ft Black is back in stock or available for preorder.
The Alphasonik AW8250G 8 Gauge Ground Wire Roll is designed to offer exceptional electrical conductivity, ensuring your audio system has a stable and efficient ground connection. The 8 gauge thickness minimizes resistance and power loss, making it ideal for high-power installations where reliability and performance are crucial. This wire is perfect for both amateur and professional setups, providing the consistent connection needed for superior audio quality.
Constructed from premium materials, this ground wire is built to withstand the demanding conditions of automotive environments. Its robust construction guarantees long-lasting performance, while the durable insulation protects against abrasion and harsh conditions. This makes it a reliable choice for both routine use and complex installations, ensuring your system remains securely grounded over time.
With an extensive 250 feet of wire, the Alphasonik AW8250G offers the flexibility to handle a wide range of installation projects without the worry of running short. The black color not only looks sleek but also seamlessly blends with most vehicle interiors and setups. Whether you’re upgrading your car’s audio system or embarking on a new installation, this ground wire provides the versatility and quality needed to achieve professional results.
BrandAlphasonik
ModelAW8250G
Part Number268-720
UPC850009208385
Weight20
