  • Adire Audio ADBR15D4RA Brahma 15" XBL DVC Subwoofer
CLEARANCE Adire Audio ADBR15D4RA Brahma 15" XBL DVC Subwoofer
Adire AudioPart # 294-118
Model: ADBR15D4RA
1 Question, 1 Answer or
The legend is back! Parts Express is pleased to announce the addition of Adire Audio, the makers of the original XBL^2 high excursion subwoofer drivers. The Brahma Mk2.5 RA subwoofers are upgrades to the original industry standard for low distortion, extreme linearity and excursion capability. If you are looking for ultra high-output, low distortion and near-endless excursion capability, look no further.
  • Patented XBL^2 Linear Motor Technology
  • Hi Temp 3” Flat Wound Copper Voice Coil
  • Heavy Duty Lead Wires Interwoven into Spiders
  • Dual Progressive Spiders
  • Hand assembled in the U.S.A.
We'll send you an email when Adire Audio ADBR15D4RA Brahma 15" XBL DVC Subwoofer is back in stock or available for preorder.
The ultimate solution for ultra high excursion, linearity and low distortion
The Adire Audio Brahma has always been known as a legendary driver in the audio industry since the very inception of the namesake in 2002. At that point in time, Adire Audio were at the forefront of high excursion drivers pushing the envelope to truly linear excursion levels never seen before. Fast forward to 2019 and they have gone back to the drawing board - updating the designs to surpass current industry standards while utilizing Patented XBL^2 motor technology to carry on the legendary namesake of the Adire Audio Brahma.
In 2021, upgrades were added to the popular Mark 2.5 Brahma design which include a new basket with custom tooled spider adapter for better fit and clearances, carbon fiber dust cap and a 100% Nomex spider for better long-term durability. These upgrades are on top of the completely revamped from-the-ground-up design implemented in 2018 which include utilizing a dual stack of Y35 Grade ceramic ferrite magnets and a fully finite element analysis optimized motor structure. Dubbed the Brahma Mark 2.5 Rev A, the driver has been made more compact than the original Brahma for the end user who may be concerned about mounting depth constraints, all the while improving the original legendary performance of the very first Brahma.
Unable to find a spider they were happy with, Adire developed their own proprietary dual 8” progressive roll spider profile. After more than 2 years of material testing, they settled on a 100% Nomex weave for long term durability. This technology is just one small piece of the redesign puzzle which adds up to allow Adire to keep the Brahma Mark 2.5 Rev A as sound quality oriented as possible, without sacrificing overall SPL output.
The Brahma Mark 2.5 Rev A carries on the world-class sound quality and tonal balance of the original Brahma while still being able to pump out insane SPL output. Doing all of the above in such a clean fashion can only be achieved using XBL^2 motor technology which is why Adire has not swayed from tradition.
The Brahma Mark 2.5 Rev A is rated at 1000 watts RMS power handling and features a 3” diameter copper voice coil available in Dual 2 or Dual 4 ohm that will keep you enjoying your music at all levels of excursion and output for many years to come.
The Brahma Mark 2.5 Rev A is an audio enthusiasts dream and will bring out the bottom octaves in a truly unique style!
BrandAdire Audio
ModelADBR15D4RA
Part Number294-118
UPC753459798577
Weight42.75
Nominal Diameter15"
Sensitivity87.16dB 2.83V/1m
Voice Coil Diameter3"
Resonant Frequency (Fs)24.66Hz
DC Resistance (Re)6.77Ω
Voice Coil Inductance (Le)3mH
Mechanical Q (Qms)5.28
Electromagnetic Q (Qes)0.5
Total Q (Qts)0.46
Compliance Equivalent Volume (Vas)4.13ft³
BL Product (BL)17.59T·m
Diaphragm Mass Inc. Airload (Mms)317.15g
Maximum Linear Excursion (Xmax)28mm
Surface Area of Cone (Sd)791.73cm²
Cone MaterialPaper
Overall Outside Diameter15.625"
Baffle Cutout Diameter14"
Depth8.125"
Sealed Volume2.25ft³
Sealed F342.6Hz
Vented Volume4.5ft³
Vented F323.6Hz
