  • ART XConnect XLR to USB Cable
CLEARANCE ART XConnect XLR to USB Cable
ARTPart # 245-8663
Model: XConnect
The ART XConnect USB Microphone Cable provides an easy way to directly connect any dynamic microphone to your computer’s USB port for convenient recording without any extra equipment.
  • Plug and play USB recording for any dynamic microphone for Windows and Mac OS
  • Shielded cable with female XLR connector
  • High quality 16-bit, 44.1 kHz or 48 kHz digital audio interface
  • LED indicator flashes during signal transmission
We'll send you an email when ART XConnect XLR to USB Cable is back in stock or available for preorder.
The ART XConnect USB Microphone Cable provides an easy way to directly connect any dynamic microphone to your computers USB port for convenient recording without any extra equipment. The output of the XConnect is a studio quality 16-bit, 44.1 kHz or 48 kHz digital audio signal. No special drivers are required, just “plug and play” with your Windows PC or Mac.
Simply plug the XLR connector into your microphone and the USB connector into your computer. That is all there is to it. The first time you connect your XConnect to your computer, all the necessary drivers will be automatically installed and the cable will then be ready to use. The XConnect may be used with any recording software that supports USB audio devices.
Connectors: Female XLR (unbalanced), USB "A "
Input impedance: 1 Mohm
THD + N: <0.05%
Signal to noise ratio: 80 dB
Dynamic range: 83 dB
Frequency response: 20-19,000 Hz (48 kHz)
Maximum input level: +2 dBu
Maximum gain: +23 dB
Length: 10 ft
BrandART
ModelXConnect
Part Number245-8663
UPC840402019503
Weight0.6
