  • ART USBII 2 x 4 USB / MIDI Digital Interface
CLEARANCE ART USBII 2 x 4 USB / MIDI Digital Interface
ARTPart # 245-8657
Model: USBII
High quality recordings require high quality gear, but not always at a high price! ART has created the USB II audio interface with 2 channels of 32bit AD/DA converters and a sampling rate up to 192kHz to provide you archive-quality recordings. Powerful output options lets you have two different mixes for headphone and monitor outputs, and low latency monitoring makes sure you’re right on the beat! Includes Midi input and output sections for your outboard drum machines and keyboards, all the features you need to make a hit!
  • 2 XLR Combo Inputs
  • 2 Mono, 1 Stereo 1/4" Output
  • 32-bit/192kHz Resolution
  • MIDI Input and Output
  • USB Powered and supported by Windows and OSX
  • Low Latency Monitoring
  • Phantom Power
We'll send you an email when ART USBII 2 x 4 USB / MIDI Digital Interface is back in stock or available for preorder.
ART has created the USB II audio interface with 2 channels of 32bit AD/DA converters and a sampling rate up to 192kHz to provide you archive-quality recordings. Powerful output options lets you have two different mixes for headphone and monitor outputs, have the musician hear the metronome and you can hear what you're recording! Native low latency monitoring makes sure you’re right on the beat with no software necessary! Fully compatible with CoreAudio, WDM, and ASIO drivers for use with any DAW or ecosystem. Audio is not all this guy does well! MIDI input and output sections with high performance clocking are available for your outboard drum machines and keyboards with minimum flutter. The USB II provides all the features you need to make a hit with a single USB cable!
  • High-quality 32-bit AD/DA converters
  • Low latency ASIO and WDM driver support
  • High/Low-Z mic and instrument combo inputs
  • Front panel headphone output
  • MIDI Input/Output
  • 44.1kHz to 192kHz Sampling Rate
BrandART
ModelUSBII
Part Number245-8657
UPC840402047407
Weight3.25
Active / PassiveActive
