ART USB Phono Plus Project Series Phono Preamp with USB Interface
We'll send you an email when ART USB Phono Plus Project Series Phono Preamp with USB Interface is back in stock or available for preorder.
The USB Phono Plus is the ideal solution for transferring any highly prized vinyl collection to a modern digital format. It is also the ideal high performance audio interface between analog and digital sources. The built in low-noise RIAA phono preamp circuit with low cut filters (to remove rumble and noise) guarantees pristine audio capture.
Front mounted gain control and Signal/Clip LED allows easy optimization of a wide range of analog input sources. The USB Monitor/headphone provides zero latency monitoring of the input source for easy cueing. The USB PhonoPlusPS can also act as audio playback source for any USB equipped computer or laptop. Optical TOSLINK Input and Output as well as an S/PDIF Input make the USB PhonoPlusPS an ideal analog / digital audio to USB interface as well.
The built-in low noise Phono Preamp circuit is highly accurate and precisely conforms to the RIAA standard. The Line Out jacks are always connected to the input preamp signal for source monitoring or to allow use as a stand-alone phono preamp.
Housed in an all aluminum black anodized case, the USB PhonoPlusPS can be powered by either external power supply or directly via USB port. To ensure maximum versatility, the USB PhonoPlusPS is fully compliant with the USB 2.0 specification and uses USB adaptive mode for playback and USB asynchronous mode for record. It will work with Windows 98SE/ME/2000/XP/Vista/7 USB audio device drivers as well as Apple OS9.1/OS-X computers with native USB support.
USB PhonoPlusPS ships with SoundSaver Express software.
Specifications: • Frequency response: 10 - 50,000 Hz, ±0.5% • Dimensions: 1.85" x 4.6" x 4.5" (47 x 117 x 114 mm) • Weight: 1.35 lbs. (0.61kg)
Product Details | |
| Brand | ART |
| Model | USB PhonoPlusPS |
| Part Number | 245-8686 |
| UPC | 840402019527 |
| Unit of Measure | Each |
| Weight | 1.85 |
