  • ART Tube MP Tube Mic Preamp with 48V Phantom Power
CLEARANCE ART Tube MP Tube Mic Preamp with 48V Phantom Power
ARTPart # 245-8606
Model: TUBE MP
The Tube MP is the world's most popular external tube microphone preamp. While its primary application is to be used with a microphone, the Tube MP is an exceptional direct box - impedance matching, amplifying and improving the sound of any instrument plugged into it.
  • Provides superior preamplification for microphones, instruments and line level sources
  • Hand selected 12AX7a provides 70 dB of gain smooth, warm and fat sound quality
  • Variable input and output gain controls
  • Excellent as a Tube DI
  • XLR and 1/4" inputs and outputs
  • +48V phantom power
  • Phase reversal switch
CLEARANCE $129.99
Save $56.00 (30%)
2 In Stock
We'll send you an email when ART Tube MP Tube Mic Preamp with 48V Phantom Power is back in stock or available for preorder.
The Tube MP is the world's most popular external tube microphone preamp. Whether you're working with a digital, computer or analog recording system, the Tube MP's TEC award nominated design will allow you to obtain professional recording studio results at a fraction of the cost of comparable equipment. The hybrid design of the Tube MP allows it to add warmth and fatness to a signal while maintaining exceptionally low-noise and high quality. While its primary application is to be used with a microphone, the Tube MP is an exceptional direct box - impedance matching, amplifying and improving the sound of any instrument plugged into it. The usage of external mic/line preamps has become increasingly popular over the past several years. The Tube MP offers superior performance and sound quality to the on-board preamps found in today's low-cost mixers and multi-trackers. It's sound has been consistently favored over other products costing upwards to ten-times its price. Professional quality sound combined with professional features like: a hand-selected 12AX7a tube, phantom power and phase reverse are what have made the Tube MP a staple in thousands of studios worldwide. For a minimal investment, a Tube MP can provide the single largest improvement to the sound of your studio.
Specifications: • Dynamic range: >100 dB (20 Hz to 20 kHz) • Equivalent input noise: -129 dBu ('A' weighted XLR to XLR) • Frequencyr esponse: 10 Hz to 20 kHz (+0,-1dB) • Input impedance: 2k ohms (XLR), 840K ohms (1/4") • Maximum gain: 70 dB (XLR to XLR typical) • Maximum input level: +14 dBu (XLR), +22 dBu (1/4") • Maximum output level • +28 dBu (XLR), +22 dBu (1/4") • Output impedance: 600 ohms (XLR), 300 ohms (1/4") • Total harmonic distortion: <0.1% (typical) • CMMR: >75 dB (typical @ 1 kHz) • Power requirements: 9 VAC @ 700mA (typical) • Dimensions: 5.0" D x 5.5" W x 2.0" H.
BrandART
ModelTUBE MP
Part Number245-8606
UPC840402011415
Weight2.4
