  • ALPS 250KAX2 250K Ohm Audio Taper Stereo Potentiometer 6mm Shaft
CLEARANCE ALPS 250KAX2 250K Ohm Audio Taper Stereo Potentiometer 6mm Shaft
Parts ExpressPart # 023-202
Model: 250KAx2
The Alps 250KAX2 is a 250K ohm stereo potentiometer of the highest quality. The 6 mm straight shaft is 25 mm long with M8 thru-hole mounting, hardware included. For over 6 decades, Alps has been made in Japan, and has also been the only choice for serious musicians, audiophiles, and technicians.
We'll send you an email when ALPS 250KAX2 250K Ohm Audio Taper Stereo Potentiometer 6mm Shaft is back in stock or available for preorder.
The Alps 250KAX2 is a 250K ohm stereo potentiometer of the highest quality. The 6 mm straight shaft is 25 mm long, with M8 thru-hole mounting, hardware included. The body of the potentiometer is 1.073" W  x 0.97" H x 0.93" D (27 x 24.5 x 24 mm) without terminals. 1/2 watt power rating, 30 VAC max. For over 6 decades, Alps has been made in Japan, and has also been the only choice for serious musicians, audiophiles, and technicians.
Maybe you're repairing, restoring, or hot rodding an existing guitar, amplifier, or other electronic equipment. Perhaps you're devising your own unique musical or audio gear from scratch, working on classic vintage receivers, radios, or TV sets. Any way you slice it, Parts Express has the quality components you need to finish the job right, at prices you can afford.
Model250KAx2
Part Number023-202
UPC848864029726
Electrical CharacteristicsLogarithmic / Audio Taper
Value250K
