CLEARANCE ALPS 100KAX2 100K Ohm Audio Taper Stereo Potentiometer 6mm Shaft
We'll send you an email when ALPS 100KAX2 100K Ohm Audio Taper Stereo Potentiometer 6mm Shaft is back in stock or available for preorder.
The Alps 100KAX2 is a 100K ohm stereo potentiometer of the highest quality. The 6 mm straight shaft is 25 mm long, with M8 thru-hole mounting, hardware included. The body of the potentiometer is 1.073" W x 0.97" H x 0.93" D (27 x 24.5 x 24 mm) without terminals.1/2 watt power rating, 30 VAC max. For over 6 decades, Alps has been made in Japan, and has also been the only choice for serious musicians, audiophiles, and technicians.
Maybe you're repairing, restoring, or hot rodding an existing guitar, amplifier, or other electronic equipment. Perhaps you're devising your own unique musical or audio gear from scratch, working on classic vintage receivers, radios, or TV sets. Any way you slice it, Parts Express has the quality components you need to finish the job right, at prices you can afford.
Product Details | |
| Brand | Parts Express |
| Model | 100KAx2 |
| Part Number | 023-206 |
| UPC | 848864029740 |
| Unit of Measure | Each |
| Weight | 0.05 |
Product Specifications | |
| Electrical Characteristics | Logarithmic / Audio Taper |
| Value | 100K |
