  • ADJ MYDMX GO 256-Channel Wireless DMX Lighting Controller for iPad and Android Tablets
CLEARANCE ADJ MYDMX GO 256-Channel Wireless DMX Lighting Controller for iPad and Android Tablets
ADJ
Part #244-4237
ADJ
Part #244-4237
Model: MYDMX GO
The ADJ mydmx GO is an easy to use lighting control app that connects wirelessly for iPad, Android or Amazon Fire tablets. Giving you complete control over your lighting rig, the ADJ mydmx Go is perfect for on the go DMX programming.
  • DMX Lighting Control App for iPad or Android Tablets
  • 256 DMX channels over Wi-Fi and USB for wireless operation
  • Library of 15,000+ lighting fixtures makes it easy to get up and running
  • Manual Channel Control and Light Position Calibration
  • 21 Automatic Effects allow you to create dazzling shows in no time
ADJ’s mydmx GO is a revolutionary new lighting control system that is extremely powerful and incredibly easy to use. It combines a uniquely intuitive app-based control surface with a compact interface that connects wirelessly to an iPad, Android, or Amazon Fire tablet and provides a standard 3-pin XLR output for connection to a lighting system.
The mydmx GO app requires zero programming but can be used to create stunning synchronized lightshows across any combination of lighting fixtures. It’s distinctive layout features two FX wheels with one for color chases and one for movements patterns, which each contain eight pre-programmed effects. These can be selected independently, customized (by altering the color palette, speed, size, shift and fan) and combined to create a vast number of different unique effects which can then be stored for instant recall to one of 50 user-defined presets. In a matter of seconds, incredible lighting displays can be easily created that would require hours of programming using traditional control systems.
With an extensive fixture library of 15,000+ profiles, the mydmx GO can be used to control all types of DMX lighting from any manufacturer. It is ideal for use by mobile entertainers as well as for small nightclubs, bars and leisure venues where a simple and easy to use lighting control system is required.
DMX channels: 256 (expandable to 512 with additional purchase from ADJ
DMX connection:USB, Wi-Fi
Lighting fixture presets:15,000 fixtures
Manual controls:Light position calibration, channel control
Automatic effects: 21
User presets: 50
Controls: Speed, size, shift, fade, fan
iPad Compatibility
Requires iOS 10.0 or later. Compatible with iPad Air, iPad Air Wi-Fi + Cellular, iPad mini 2, iPad mini 2 Wi-Fi + Cellular, iPad Air 2, iPad Air 2 Wi-Fi + Cellular, iPad mini 3, iPad mini 3 Wi-Fi + Cellular, iPad mini 4, iPad mini 4 Wi-Fi + Cellular, 12.9-inch iPad Pro, 12.9-inch iPad Pro Wi-Fi + Cellular, 9.7-inch iPad Pro, 9.7-inch iPad Pro Wi-Fi + Cellular, iPad (5th generation), iPad Wi-Fi + Cellular (5th generation), 12.9-inch iPad Pro (2nd generation), 12.9-inch iPad Pro Wi?Fi + Cellular (2nd generation), 10.5-inch iPad Pro, 10.5-inch iPad Pro Wi?Fi + Cellular, iPad (6th generation), iPad Wi-Fi + Cellular (6th generation), iPad Pro (11-inch), iPad Pro (11-inch), iPad Pro (12.9-inch) (3rd generation), and iPad Pro (12.9-inch) (3rd generation).
Compatible with Android Tablets or Amazon Fire Tablets 4.0.3 and up
Downloads
iPad App
Andriod App
Amazon Fire App
BrandADJ
ModelMYDMX GO
Part Number244-4237
UPC818651026054
Weight1.45
