  • AC Infinity CLOUDPLATE T5 PRO 1U Rack Cooling System with Rear Exhaust
AC InfinityPart # 305-416
Model: CLOUDPLATE T5 PRO
The Cloudplate T5 Pro 1U rack cooling system utilizes a programmable fan speed controller, enabling it to work for a wide range of rack mount applications. With a noise level as low as 9 dBA, this fan system can be used for environments where low or minimal noise necessary such as home theater, studio, DJ, and audio video racks. A max airflow rating of 180 CFM will provide adequate cooling to server, network, IT and equipment racks requiring high airflow.
  • An intelligent fan system designed for cooling A/V, DJ, server, network, and IT equipment racks
  • This kit protects rack-mount equipment from overheating, performance issues, and shortened lifespans
  • Programmable thermostat controller with automated speed control, alarm warnings, and backup memory
  • Premium anodized aluminum construction with CNC-machined detailing for a professional appearance
Your Price: $189.00
We'll send you an email when AC Infinity CLOUDPLATE T5 PRO 1U Rack Cooling System with Rear Exhaust is back in stock or available for preorder.
Order in the next 4 hr 0 min to ship today. Details
This intelligent cooling fan system can be used for environments where low or minimal noise is necessary such as home theater. Maintaining an optimal temperature for rack-mount equipment prevents overheating, ensures constant performance, and extends their lifespan. Improper ventilation and cooling is one of the most common reasons for equipment failure in A/V equipment.
The LCD digital controller features a programmable thermostat with automated speed control, alarm warnings, status alerts, and backup memory. This system is housed in a solid aluminum construction that takes up one rack unit (1U) of space. Each aluminum frame is anodized with a light-brush finish, then the corners CNC-machined and edges chamfered for a high-end professional appearance. The fans contain dual ball bearings rated at 67,000 hours, a testament to their longevity.
The fans are designed to exhaust hot air and should be positioned near the top of the rack. This complete kit includes the 1U fan unit, corded 6-ft thermal probe, user’s manual, rack mount screws, cage nuts, and corded 6-ft power supply.
Specifications: • Input voltage: 12 VDC • Power supply input: 100 - 240 VAC • Rack mount size: 1U • Design: Rear exhaust • Total airflow: 40 - 180 CFM • Total noise: 9 - 32 dBA • Cord length: 6 ft. • Dimensions: 19.0" x 1.75" x 13.5".
BrandAC Infinity
ModelCLOUDPLATE T5 PRO
Part Number305-416
UPC819137020009
Weight9.6
