  • AC Infinity AXIAL 8038 Low Speed Fan Kit with Plug Cord
AC InfinityPart # 305-408
Model: AXIAL 8038
This low speed fan is ideal for applications that require a lower noise level and don't require a large amount airflow. The most common uses include theater cabinets, woodstove heaters, room to room doorways, amplifiers, kegerators, and more. Because this is a standard industrial size fan, it can be used to replace fans found in various electronics and machinery.
  • This fan is designed for projects that require cooling or ventilation; or as a replacement fan for various products
  • Includes a heavy-duty aluminum fan with a power cord, two fan guards, and mounting screws
  • This low speed fan has a lower noise and airflow rating than high speed models
Your Price: $18.99
We'll send you an email when AC Infinity AXIAL 8038 Low Speed Fan Kit with Plug Cord is back in stock or available for preorder.
Estimated back in stock 1/22/2026
This heavy duty axial fan kit is ideal for custom projects and as a replacement fan. Maintaining an optimal temperature for A/V equipment prevents overheating, ensures constant performance, and extends lifespan. Improper ventilation and cooling is one of the most common reasons for failure in A/V equipment. This complete kit includes the fan unit, user’s manual, and corded 4-ft power cable.
Specifications: • Input voltage: 100 - 125 VAC • Total airflow: 23 CFM • Total noise: 28 dBA • Cord length: 4 ft. • Dimensions: 3.15" x 3.15" x 1.5".
BrandAC Infinity
ModelAXIAL 8038
Part Number305-408
UPC854759004273
Weight1.05
