  • AC Infinity AIRPLATE S7 12" Dual Fan Assembly with Speed Control
AC InfinityPart # 305-404
Model: AIRPLATE S7
This whisper-quiet fan system is designed to cool home theater components, entertainment centers, and A/V cabinets. The dual fan design provides a large amount of air movement without a high sound level.
  • The ultra-quiet blower system creates minimal noise for installations requiring a quiet environment
  • Low-profile, aluminum frame design makes mounting in a confined space easy
  • The multi-speed controller allows the user to set the fan’s speed to optimal noise and airflow levels
  • The included Turbo Adapter increases performance by 25%
Your Price: $49.99
We'll send you an email when AC Infinity AIRPLATE S7 12" Dual Fan Assembly with Speed Control is back in stock or available for preorder.
This ultra-quiet cooling system is easily able to be integrated into a variety of applications including home theaters, entertainment centers, and A/V cabinets. Improper ventilation and cooling is one of the most common reasons for equipment failure in A/V equipment. When heat is trapped inside a cabinet with home A/V equipment, the components of the equipment can be raised to temperatures that cause failure, and require a costly repair.
The fans are set to exhaust air out of the cabinet but this can be reversed to intake air using a screw driver. The fans included in this system use a custom-engineered motor to minimize noise during speed variations. Includes all necessary hardware to easily mount the unit onto a cabinet and power it through an USB port or standard wall outlet. The fans contain dual ball bearings rated at 67,000 hours, a testament to their longevity.
These fans can be mounted in any direction or orientation. They feature a CNC-machined anodized aluminum frame with a modern brushed black finish. The included speed controller and 6-foot power cord making installation and utilization extremely easy. All necessary hardware to easily mount and install the unit onto a cabinet and power it through an USB port or standard wall outlet are included.
Specifications: • Input voltage: 3 - 7 VDC • Wall adapter input: 100 - 240 VAC • Total airflow: 104 CFM • Total noise: 19 dBa • Cord length: 6 ft. • Dimensions: 11.7" x 6.1" x 1.3".
BrandAC Infinity
ModelAIRPLATE S7
Part Number305-404
UPC854759004068
Weight2.2
Product TypeCooling Systems
