  • AC Infinity AIRPLATE S3 6" Home Theater and AV Cabinet Cooling Fan System with Speed Control
AC InfinityPart # 305-402
Model: AIRPLATE S3
This ultra-quiet blower system is designed to cool home theater components, entertainment centers, and A/V cabinets. The square design provides an obvious aesthetic beauty that can be a huge benefit for installations on display in your home or a venue.
  • The ultra-quiet blower system creates minimal noise for installations requiring a quiet environment
  • Low-profile aluminum frame design makes mounting in a confined space easy
  • The multi-speed controller allows the user to set the fan’s speed to optimal noise and airflow levels
  • The included Turbo Adapter increases performance by 25%
Your Price: $34.99
We'll send you an email when AC Infinity AIRPLATE S3 6" Home Theater and AV Cabinet Cooling Fan System with Speed Control is back in stock or available for preorder.
This ultra-quiet cooling system is easily able to be integrated into a variety of applications including home theaters, entertainment centers, and A/V cabinets. Improper ventilation and cooling is one of the most common reasons for equipment failure in A/V equipment. When heat is trapped inside a cabinet with home A/V equipment, the components of the equipment can be raised to temperatures that cause failure, and require a costly repair.
The fans are set to exhaust air out of the cabinet but this can be reversed to intake air using a screwdriver. The fans included in this system use a custom-engineered motor to minimize noise during speed variations. Includes all necessary hardware to easily mount the unit onto a cabinet and power it through an USB port or standard wall outlet. The fans contain dual ball bearings rated at 67,000 hours, a testament to their longevity.
These fans can be mounted in any direction or orientation. They feature a CNC-machined anodized aluminum frame with a modern brushed black finish. The included speed controller and 6 ft. power cord make installation and utilization extremely easy. All necessary hardware to easily mount and install the unit onto a cabinet and power it through an USB port or standard wall outlet are included.
Specifications: • Input voltage: 3~7 VDC • Wall adapter input: 100~240 VAC • Total airflow: 52 CFM • Total noise: 18 dBa • Cord length: 6 ft. • Dimensions: 6.3" x 6.3" x 1.3".
BrandAC Infinity
ModelAIRPLATE S3
Part Number305-402
UPC854759004006
Weight1.4
Product TypeCooling Systems
