  • 9V 1A Power Supply AC Adapter with 6 ft. Cord 2.1 x 5.5mm Center Negative (-) Plug
Parts ExpressPart # 120-060
This 9-volt power supply is perfect for guitar effects pedals, pedal boards, and more. With 9 VDC output and a center negative 2.1 x 5.5 mm plug, it is suitable for many keyboards, samplers, drum machines, and other devices. Please confirm that your gear operates with center negative polarity to avoid damage.
  • AC prongs are rotated 90° to avoid covering up both wall outlets
  • Standard size 2.1 x 5.5 DC plug
  • Meets level VI standby efficiency
  • ETL certified for safety
  • 100-240 VAC 50/60 Hz input for international use
Your Price: $6.39
Save $6.60 (51%)
177 In Stock
We'll send you an email when 9V 1A Power Supply AC Adapter with 6 ft. Cord 2.1 x 5.5mm Center Negative (-) Plug is back in stock or available for preorder.
Order in the next 2 hr 46 min to ship today. Details
This 9-volt power supply is perfect for guitar effects pedals, pedal boards, and more. With 9V DC output and a center negative 2.1 x 5.5 mm plug, it is suitable for many keyboards, samplers, drum machines, and other devices. UL and Level VI certified. Please confirm that your gear operates with center negative polarity to avoid damage. The AC prongs are rotated 90 degrees, compared to other AC adapters, to avoid covering up both wall outlets.
Specifications: • Output power: 9 VDC, 1000 mA • Voltage input: 100-240 VAC @ 50/60 Hz • Plug size: 5.5 x 2.1 x 10 mm Polarity: Center negative (-) • Cord length: 6 ft. • Dimensions: 1.15" W x 2.89" H x 1.82" D without AC prongs at the deepest point.
Part Number120-060
UPC848864032818
Weight0.25
Center/Tip PolarityCenter Negative
Current Capacity1000mA
DC Output Voltage9V
Input Voltage100~240 VAC
Plug Size2.1 x 5.5 mm
