  • 9-1/4" Large Gauge Wire & Cable Cutter
CLEARANCE 9-1/4" Large Gauge Wire & Cable Cutter
Parts ExpressPart # 360-624
This large diameter cable cutter is designed to cut up to 4/0 aluminum and 2/0 copper wire. Carbon steel construction with extra long handles for maximum cutting leverage. Jaws of cutter are curved for a quick and easy cut while not disturbing the characteristics of the cable.
CLEARANCE $17.98
MSRP: $20.99
Save $3.01 (14%)
Quantity:Qty: 1-5 $17.98/ea
Quantity:Qty: 6+ $15.98/ea
67 In Stock
We'll send you an email when 9-1/4" Large Gauge Wire & Cable Cutter is back in stock or available for preorder.
Order in the next 3 hr 31 min to ship today. Details
This large diameter cable cutter is designed to cut up to 4/0 aluminum and 2/0 copper wire (9.2 mm Dia.). Carbon steel construction with extra long handles for maximum cutting leverage. Jaws of cutter are curved for a quick and easy cut while not disturbing the characteristics of the cable. Also has a small shearing hole for cutting steel wire up to 3.0 mm to prevent the blade from getting dull or nicked. Overall length is 9-1/4".
Part Number360-624
UPC844632015083
Weight1
